Old 04-14-2007, 11:14 PM
jumpingjack66's Avatar
jumpingjack66 jumpingjack66 is offline
Send a message via Yahoo to jumpingjack66
Thumbs up gm part numbers for feul pump
Wondering if someone could provide me with the two possable part numbers for fuel pump on my 2000 silvy with short bed standerd cab 4.8 5 speed. 4x4....i want to do som price searching...jj
, or maybe someone knows of an upgraded aftermarket pumpmaker who is making a better oem pump? holly? carter? edelbrock?.. ant help wuold be appreciated.. only want to do this once...j
2000 Silverado Victory Red, standard cab, short bed, short wheelbase, 4X4, 4.8L, 5 speed, 4:10 locking rear diff, K&n FIPK, Ryno lined all the way over bed rail, heavy half suspension,factory skid plates,Fog lights, BFG 285/75/16 A/T's, dashmat, Stealth Radar.
lots of special options some installed by me!
1980 Suzuki GS1100E Super fast
Old 04-15-2007, 11:38 AM
rjeffery rjeffery is offline
Re: gm part numbers for feul pump
If you only want to do it once, difinitely go with the OEM pump. I don't recall exact part numbers, but when I did mine, there were two options: one for trucks with the EVAP system, and one for trucks without. I got mine from Oreilleys for around $280 and some change.
Old 04-15-2007, 01:05 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
O'Reilley's has OEM parts?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 04-15-2007, 01:40 PM
Yup. They had to order it, but it was OEM
Old 04-19-2007, 11:14 AM
1955chevy's Avatar
1955chevy 1955chevy is offline
I replaced my fuel pump two weeks ago on my 2000 with a 4.8 liter. It's a two-wheel drive with a 5 speed tranny. It also has the evap system. I bought it from the local dealership who wanted $510 for it. I also called NAPA and they wanted $310. I then asked the dealer if they would lower their price and they went down to $358, so I bought it from them. I decided to remove the bed instead of dropping the tank because I dropped the tank on another truck and that was no fun. I had to splice in one new connector that was supplied with the pump along with the necessary crimp connectors. They also included a new fuse to replace an existing fuse in the fuse box under the hood. Not sure why that was necessary because the replacement fuse was the same amp rating as the old fuse. Overall, not too hard of a job if you have a way to remove the bed. I used an engine puller and it worked great. Good luck!
2000, 4.8 L, 5 speed tranny.
Old 04-19-2007, 11:18 AM
1955chevy's Avatar
Sorry, I forgot the PN. The number on my receipt and box is 19121626.
Old 04-19-2007, 11:21 AM
1955chevy's Avatar
I just looked up the part on gmpartsdirect.com and they want $265.68 for it.
