Old 04-14-2007, 06:42 PM
ColoradoSilverado ColoradoSilverado is offline
Max. Trailer Weight ?
I have A 2000, 5.3 Z71 ext. cab long bed Silverado with the trailer package. How do I find out what the maximum trailer weight is ?
Bert
Old 04-14-2007, 06:49 PM
masapell's Avatar
masapell masapell is offline
Re: Max. Trailer Weight ?
Bert
I was just looking at this last night too If you pull out your owner's manual, it is in there. You will have to know your axle gearing. Mine was around 7500, but I think the Z71 is rated higher. Are you going to join the world of camper pulling? I pull a pop-up and love it to death!!
Sincerely,
Matt
2014 Ram 1500 Crew Cab
Old 04-14-2007, 07:03 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
My 2000 5.3 ext. is either 6500 or 6800 but we never tow anything over 5500 and the truck does a great job.
Old 04-14-2007, 07:11 PM
Well, I got a landscaping business and recently bought a nice used heavy duty tandem axle utility trailer, ill be hauling mostly dirt, rocks, trees and that sort of things. Acording to my owners manual its either 7500 lbs or 8000 lbs depending on the Axle ratio, how do I find out my axle ratio ?
Bert
Old 04-14-2007, 07:26 PM
bigbadram51 bigbadram51 is offline
Look at your RPO build sheet (its the sticker on the inside of the glovebox. My guess is you have 3.73's which is GT4, GT5 is for the 4.10's, and GU6 is for 3.42's most silvys come with 3.73's
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 04-14-2007, 10:01 PM
I suppose thats the sticker on the left side ?
Bert
Old 04-16-2007, 06:49 AM
Turns out I have the 3.73 gears (GT4). So, max. trailer weight is 7500 lbs, trailer weighs in at 2000 lbs. So, the max. I can load is about 2.5 tons.
Bert
Old 04-16-2007, 10:20 AM
wrparks wrparks is offline
If your going to be towing anywhere near your maximum capacity or if you are towing alot of relatively light loadsa long way, I'd recommend a tranny cooler be added to your setup to keep things working longer.
Old 04-16-2007, 11:42 AM
If you have the towing package, doesn't it already have a tranny cooler. I thought so anyway
3" PA Body Lift
Covermaster Top
Old 04-16-2007, 06:54 PM
Doh, good point. I think your right. It helps to read carefully huh? lol
Old 04-16-2007, 09:37 PM
Yup, got the tranny cooler. Just need to get a brake controller.
Bert
Old 04-16-2007, 10:22 PM
Sonny01's Avatar
I have a digital Prodigy...some places sell them for like $189.95...I got mine new on eBay for under $100. You don't have to adjust it when going up or down hills. It works great!
Old 04-17-2007, 02:47 PM
Sonny01's Avatar
I just dug out my manual to double check my max towing weight and it's 7500 also...I must have been thinking about my old truck being 6500 or 6800lbs.
Old 04-17-2007, 02:58 PM
masapell's Avatar
Ahh, I remember when I was at the dealership a couple of years ago, about to purchase my truck. When I questioned the salesman about the truck and told him about the fact that I was going to be towing with it, he said "this truck is perfect because it has the trailering package"! Well, I really did not know what that meant, so I asked him what that included. He said that it had tow/haul mode, so it was set up for towing. Since I was uninformed at the time (I should have visited this site much sooner), I went along with that explanation. I did ask where the hitch was, and was informed that it had probably been taken off, but they could have one installed at an extra cost. About a month later, I figured out that it DID NOT have the trailering package (no hitch, no tranny cooler, and 3.42 gears). So, I had to add the hitch, cooler, and wiring myself. The next time I will definitely do more research!!! Lesson learned.
Sincerely,
Matt
