Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 04-14-2007, 02:39 PM
guiller guiller is offline
E36 316i Idle Problem
I'll have done the Following but sometime its happend again
I'll clean the IDLE REGULATOR VALVE.
I'll change my 4 SPART PLUG.
I'll adjust the small screw located in THROTTLE valve and also the THROTTLE cable.
I'll check all the hose, its fine.
iTS ANY REASON TO CHANGE MY ECU, BRAND NEW REGULATOR VALVE, AIR FLOW SENSOR OR CHECK MY INTAKE MANIFOLD GASKET AND THROTTLE VALVE GASKET
Old 04-14-2007, 04:34 PM
CassiesMan's Avatar
CassiesMan CassiesMan is offline
AF Vendor
Send a message via AIM to CassiesMan
Re: E36 316i Idle Problem
What exactly is the problem? Idle off? Idle high or low? Stalls at idlea? Need to go a bit more in depth here.
2006 Redline Red Nissan 350Z Base
K&N|Falken
I am just that JDM tight, yo.
Old 04-15-2007, 01:08 PM
Thanks for replying me,
The problem, every morning when i'm start the engine I need to wait 5min to 10min to go, because the idle nedle clock are keep going down and up, betwen 500 to 1000rpm then stay in 800rpm something.
When i'm on traffic light or stop for any reason the idle clock is going down and the engine are vibrating nearly to stop, all i have to do is step slighly to accelirator pedal. There is not happend all the time.
Driving are fine, sometimes when I'm fully stop (neutral or 1st gear but on clutch) rpm not normal sometimes 1000rpm, sometimes below 600rpm the engine nearly to turn off because the engine are vibrating.
Thank you so much again I hope you can help me.
Old 04-15-2007, 01:47 PM
CassiesMan's Avatar
AF Vendor
Hmmm. Sounds like your first problem may be a cold start issue, I get that sometimes when the temp gets real low out here and I start it up.
The stop light issue sounds like it is idleing to low and that the motor is on the verge of stalling. Not sure exactly what would cause that, and we never got the 316i here in the states.
I would recomend taking it to a trusted mechanic who knows Bimmers, see what he has to say. Not to sure how it works in the rest of the world, but you should be able to at least get him to tell you what is wrong as a free estimate. That should give you a good idea at whats wrong, and might give us some extra clues to fixing it.
K&N|Falken
Old 09-20-2007, 12:27 PM
mcalvo's Avatar
mcalvo mcalvo is offline
Send a message via MSN to mcalvo Send a message via Yahoo to mcalvo
Man.. did you find the cause of your idle problem? I got a similar problem with my 320i.. I think it should be something relating an air leak from the intake.
Any suggestion will be highly appreciated.
Regards,
MC
1994 E36 320i German made. http://forums.cjb.net/bmwclubcr-about49.html
