Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 04-14-2007, 12:05 PM
sreilly77's Avatar
sreilly77 sreilly77 is offline
Figured out what the "clunk" sound is
So the other day I posted about hearing a "clunk" (even though I spelled it wrong the other day) sound from my front right wheel when I go over a bump or turn left in the Jeep (again, I drive a 98 Laredo 4x4 4.0L). I found out that it is the spring because I went up my driveway today and I heard the clunk and the front right of the Jeep was leaning. The spring had popped out. When I jacked up the Jeep, the spring popped back into place. So I'm hoping I can rule out the possibility of a bad spring. However, is there something that holds the spring in place from popping out like that? I've compared both springs on both sides in the front and everything looks exactly the same. I see no abnormalities. Is there something I'm missing? Help me out. Thanks guys.
Sean
Old 04-14-2007, 04:37 PM
sreilly77's Avatar
Re: Figured out what the "clunk" sound is
Nevermind I figured it out. The spring clamp is not sitting in place properly.
Sean
Old 04-15-2007, 01:59 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
My spring clamp wasn't sitting in place on the spring it was bent up not reqally doing anything at all, so I removed it, flattened the clamp out using a vise and tightened it down and it took it'shape again.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 04-15-2007, 05:00 PM
sreilly77's Avatar
Yeah that is exactly what I did to my Jeep today. But get this! When I was raising my Jeep up on my lift, the Sway Bar Linkage came out of the grommet too and I was like are you kidding me??? So I had to replace that to and since I did one side I also did the other.
Sean
