Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-14-2007, 01:27 AM
slschnep slschnep is offline
2001 suburban rear climate control problems
The rear ventilation system just blows hot air, it is a electronic climate control, it doesn't matter where i set the temp. it blows out hot. The front works just fine. Anybody have any idea's???????? THANKS
Old 04-14-2007, 01:39 PM
Da Burb Da Burb is offline
Re: 2001 suburban rear climate control problems
I had the same problem in my 96 Suburban. It was the expansion valve in the back AC unit. It was about $300 three years ago.
Old 04-15-2007, 11:55 AM
east302 east302 is offline
The valve that Da Burb mentioned has been an issue with some people. Try a search and you'll probably find more information on that.
With my Tahoe the condensate drain line for the rear AC was clogged. The carpet in the cargo area was soaked and the rear AC didn't blow cold. The drain empties from the cargo area just above the tailpipe. It's about 1-inch rubber wedge. Pinch it a few times and see if water starts pouring out.
Old 04-16-2007, 11:22 PM
I had that problem last summer, and I have already checked that. Thanks, I will have to check into the expansion valve idea!
Old 04-26-2007, 11:30 PM
Just a update-Had to have the acuator replaced in the rear ac unit-working great now-total cost $220.00 with labor
