Old 04-13-2007, 09:37 PM
LIKE2WHEEL LIKE2WHEEL is offline
Need Help Identifying a Big Block
I have the opportunity to buy a BB for cheap, but the owner knows nothing about it's origins, & I can't remove any sheetmetal before purchase. The only stamping numbers on the pad are: C1119222, & the casting numbers are: C 361959 P, & J 10 77. Behind the bellhousing it says; PASS HI PERF.I believe that means it's a '77, & I think the casting # makes it a 454, & I think the HI PERF designation is irrevelent. I am wondering if there is any way to determine if it is a 4 bolt, & what heads might be on this or any other information. Any help would be appreciated.
Old 05-30-2007, 12:09 AM
Bad81bu's Avatar
Bad81bu Bad81bu is offline
Re: Need Help Identifying a Big Block
First i would make sure its a 454 and not a 396, just a quick eyeball to the harmonic balancer will do the trick, if theres a large notch on the balancer, means its a 396 they were externally balanced. than look for the numbers behind the alternator right or p/s of the block, should be a series of numbers and letters i think there are 7 of em and the last 3 are letters. then ya can use http://www.nastyz28.com/chevy-engine-code-stampings.php to tell ya what year and what it came out of.
Hope it helps ya
Brett
Old 05-30-2007, 08:40 AM
SpinnerCee's Avatar
SpinnerCee SpinnerCee is offline
Beware of a seller that won't let you inspect the engine internals.
.:: DigitalMIX by djSpinnerCee ::.
Old 05-30-2007, 01:56 PM
SMOKSHO SMOKSHO is offline
Sorry Bad81bu but the GM 396,402 and 427 are all internally balanced and the balancer should be smooth with no notches or cut outs. The GM 454 is externally balanced and has a notched balancer or dampener.
Not being rude, just trying to help.
I ain't never had to much fun, but I keep trying.
Old 05-31-2007, 12:05 AM
Bad81bu's Avatar
Woops, that was my bad got it backwards, thank you for the correction on that i appreciate it, and i know you werent being rude, its how ya learn things.
Thank You Kindly
Brett B.
