Old 04-13-2007, 06:55 PM
bricker82's Avatar
bricker82 bricker82 is offline
Slight knock after CAI install...
2004 Grand Prix GTP CompG 3.8 S/C
32800 miles
I put a K & N FIPK CAI on Wednesday and I noticed a slight knock under acceleration, but not when idle or in park. So today I put Autolite Double Platinum 605's in to help (1 stage colder), but it's still there.
I'll be honest, I'm not sure if it's knock or just the difference in sound from the CAI. There seems to be no power loss though.
The only mods I have on the car are the CAI and a 180 Tstat, so I didn't think I'd have to use colder plugs, but I tried it anyways. I also had a Gatorback S/C belt put on, what a difference in sound there!
I really didn't want to do anything else on the car yet, as it's still under warranty. Any suggestions? Do I need the car re-tuned? U-bend delete?
I appreciate any and all input.
Thank You,
Brick
04 GTP CompG 3.8L Supercharged
K&N FIPK/180Tstat/SSC Springs/GMPP STB's/Autolite APP605's/Aluminum Grilles/SPO Tips/17" AE Alloys 185's/2 RockfordFosgate He4410 Subs & 1 P4002 Amp
Old 04-14-2007, 11:49 AM
jeepgclwj's Avatar
jeepgclwj jeepgclwj is offline
Re: Slight knock after CAI install...
Have you checked your oil level...Just curious. I havent done my FWI yet but I wouldnt think that allowing the car to get more cooler air would cause any kind of knock...
Keep us posted
358rwhp/358rwtq with stock LS1 intake
A4 3.23 lid, pacesetter lts, ory, 243 heads, SLP LMI, ZO6 cam, BBK SSI intake, 85 mm
Old 04-14-2007, 04:33 PM
bricker82's Avatar
Oil level is good. Not low at all. I use Mobil1 5w30 and a Puralator PureONE filter for that. I'm going to change my oil today though, not over the mileage, but it has been 3 months.
I will let all of you know if it helps!
Thanks!
Old 04-14-2007, 09:13 PM
bricker82's Avatar
OK, oil changed same as before Mobil1 5w30 with a Puralator PureONE filter. "Knock" is still there though. Here are some exact symptoms.
In Park, when revved between 1000 and 4000 RPM's no knock present, sounds great actually!
In Neutral, when revved same, same result, no knock.
In Drive, under acceleration between 1800 and 2500 RPM at any speed whether stopped or rolling, "knock" is present. Sounds like slight sputtering almost like the exhaust is loose, but then that noise would always be present if that was the case. When I accelerate hard ~3000 and up, no audible "knock", but the whistle is loud and may be masking it. When I accelerate low around 1500 no "knock" either.
I hope this helps a little.
Should I just schedule an appointment with the dealer to have it looked at? I really don't want to, but I want my car running smooth too!
Thank You all again!
Old 04-15-2007, 01:30 AM
04GTP-WhatLAG?'s Avatar
04GTP-WhatLAG? 04GTP-WhatLAG? is offline
its just the injectors, don't worry this is normal... when you put on the open cone you can hear your injectors "clicking" under acceleration, there is absolutely nothing wrong and get used to the sound, there is no cure, well except for going back to the factory setup...
2004 Pontiac Grand Prix GTP
Custom K&N Fenderwell Intake , 180° thermostat, 3" Down Pipe, High Flow Cat, DHP 1.0 PCM, 3.5" pulley, 1.9 Ratio Roller Rockers, 90# LS6 Valve Springs, AL104s, ZZP Motor Mounts, 17" American Eagle 192s, Magnaflow tips.
not just babies whine
Old 04-15-2007, 01:36 AM
bricker82's Avatar
I was beginning to wonder if it was normal!
I just couldn't believe that I would have a knock that caused no loss of horsepower and only occurred under very strict circumstances.
I take it you have the same sound from your GTP? I see you have quite a few more mods than me to include the (I assume) ubend delete and larger downpipe and cat. I would imagine that if anything would reduce knock that would be it!
I appreciate your advice man, thank you! I'm a little more at ease now!
Old 04-15-2007, 01:48 PM
yeah don't worry about it, its very common in these cars... As well as jeep wranglers(my friend put an open cone CAI on his jeep and has the same problem)... the injectors are just really loud on these cars, like I said, the "clicking" is always there, but with the open cone you can hear it, if you went back stock you wouldn't be able to hear it anymore... and we don't have a ubend on the '04+s, but yeah I have scanned my car and have only slight KR at the shifts, nothing major... Also you won't be able to "hear" KR so this is definitely not that, I am about 99% sure its the injectors clicking... I have(and have had) the same 'clicking' ever since I put on my K&N aircharger, a year and half and a few more lbs. of boost later, its still running like a dream... and I see you went with the AE 077s, I was torn between those and the 192s, finally decided on the 192s...
Old 04-15-2007, 02:31 PM
bricker82's Avatar
When I bought the car in 2006 it had the AE077's already on it. I am looking at changing them when I change the tires in the fall. I'm not sure what yet, but I will definately post if I change them! I like the chrome, but it is a pain to keep clean! Here is a pic of the aluminum billet accents I put under the hood.
Old 04-15-2007, 03:19 PM
i'd stick with the 077s, they are some of the nicest looking wheels on the L32s...
my engine bay looks ghetto as hell, but I couldn't care less:
the insulation keeps the Mass Air Flow much cooler and gives a more accurate reading, so its functional, if I knew of something that looked better but served the same purpose, i would gladly get rid of it... Until then, its looks riced out under the hood...
