View Poll Results: Do you like?
YES 14 87.50%
NO 1 6.25%
kinda 1 6.25%
Voters: 16. You may not vote on this poll
Old 10-13-2002, 11:57 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
Painted tails!!!
I painted my tails that I bought from EF_LSVtec, between pulling the tranny to remove the focken motor mount bolts. Eazy out my ass. Any way tell me what ya think. The pic is not to great. Ill take more tomarrow when they get mounted.
Old 10-14-2002, 12:00 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
pic?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-14-2002, 12:01 AM
Cjz89civic's Avatar
AF Premium User
no pic attached damn
Old 10-14-2002, 12:14 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Well for the time being I will throw this up in here
originally posted by otterizer @ nwhonda.net
Painting Your Taillights Red
We all hate those ugly orange blinkers on our cars. Well now you can do something about it - turn them red! Yes, not only will they be red, but they will also blink red too! No need to replace your bulbs either. For Steven's car, we chose not to mask anything. We painted the entire lense, reverse light and all. We decided that the all-red fascia would look best if everything was red, it looks cleaner that way. (to us, at least) The first time around we painted just the blinkers, but then the brake area wasn't quite color-matched, so we just painted the whole thing.
Required Materials:
Fine grit sandpaper
Candy apple red transparent spraypaint (available at any hobbyshop)
Ratchet set or wrenches
Optional:
Spray-on clearcoat (for extra protection of paint)
1. Remove stock tail lights
Remove the body panels inside the car that are directly behind the lenses, and remove the panels on the trunklid. You will see many little bolts. Take them all off, then unplug everything from the taillights. Once this is done you will be able to pull them off.
2. Wash taillights
Washing the taillights is to get all the dirt and junk off of the lenses before you begin. Just some soap and water and a sponge will work. Make sure they are completely dry before you continue.
3. Sanding the tail lights
After washing, take a piece of the fine grit sandpaper and sand in straight, even lines across the lenses. We recommend sanding in an even pattern instead of an erratic one, since the results look a bit nicer. Make sure every part is lightly but equally sanded. You don't need to scrub the lenses, just lightly sand it.
4. Wash taillights again
This step is extremely important. Make sure ALL of the sanding dust is off of the lenses before you continue, or else the paint will not stick to the surface. You won't need soap this time, basically just hose off the lenses and thoroughly dry them. Let them sit for a couple of minutes, then run your finger over them a couple times. If no dust remains, continue to the next step. Wash again if any is left behind.
5. Painting the first coat
Make sure you are in an area where nothing will possibly land on your taillights as they are drying. For example, we did this outside, and a number of times bugs landed on the lights and stuck there, so we had to get them off and start over. Also, mask off any areas you do NOT want painted, such as the reverse lights. Do a couple test sprays on some newspaper or something to get a feel for the paint. Then, in straight, smooth lines, begin painting from left to right. Once you finish from one end to the other, stop, then repeat further down until the entire area is painted.
6. Let the first coat dry
Wait 10-20 minutes for the coat to dry. If you have a fan, try setting it on a low setting and aim it at the taillights. Once they are completely dry, proceed to the next step.
7. Painting the second coat
Repeat step 5.
8. Let the second coat dry
Repeat step 6.
9. Spray on clearcoat
This step is optional. If you wish to have extra protection for your taillights, spray on one coat of clearcoat after the second coat has dried. Wait again for the clearcoat to dry.
10. Re-install taillights
Just the opposite of removing them. Once they are installed, turn on your hazards, parking lights, or whatever and see what they look like. If you don't like the way they look, remove and add another coat. Or if you completely hate it, some paint thinner will do the trick.
* Considerations:
- Too many coats will cause the paint to lose its glossiness. Keep it at around two coats. No more than three.
- If you mess up, bust out the paint thinner. It shouldn't damage your lenses. (don't quote us on that, we didn't test that theory out, we just heard it won't damage the plastic)
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 10-14-2002, 12:20 AM
Cjz89civic's Avatar
AF Premium User
ya ya ya I know there still orange that will cange also just wanted to try this out first. Its different though I have never seen anybody paint there tails 1" up and down. Plus its cailifornia legal. I know them complete red is also...
Old 10-15-2002, 09:41 PM
Cjz89civic's Avatar
AF Premium User
its intsalled
Old 10-15-2002, 09:44 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Yo, i am so gonna try that, it looks real nice!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-15-2002, 09:58 PM
Cjz89civic's Avatar
AF Premium User
closer
Old 10-15-2002, 10:16 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Hey, that looks really nice! It was really hard to tell from the first pic what I was looking at, I thought you had painted them red...
That looks great though, reminds me of some of the CRX tails that I wish would fit on a hatch.
Old 10-16-2002, 03:19 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
WTF ?? ? ?
The action you have attempted could not be performed as your session appears to be invalid. Click the below link to attempt this action again with a new session.
Well I tried to vote in the poll...I like 'em and yeah they look a lot like CRX tails.
That Accord looks tite too. So...did they just paint over the orange enough to make 'em red??
They look kinda like when Honda got smart and changed the orange to red on the Odyssey tails
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 10-16-2002, 03:54 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Its better to buy all clear tails and paint them all red since it will come out smoother looking.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 10-16-2002, 04:17 PM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
yeah but good luck find a pair of clears..... and dont say ebay, caus they are NEVER on there...beleive me im looking for a decent set.
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 10-16-2002, 04:39 PM
kris's Avatar
kris kris is offline
Off playing with fire.
There were some on the other day.
Old 10-16-2002, 05:49 PM
mdnnccivicrcr mdnnccivicrcr is offline
speaking of finding clears, anybody seen any for the 88-89 sedan lately? I'm wanting to have clear blinkers on the rear of my EX but I simply cannot find a set.
90 Civic EX *RIP*
90 CRX DX *RIP*
88 Civic DX Sedan (pushing boost) *RIP*
95 Accord LX Sedan
Old 10-16-2002, 10:39 PM
Melt's Avatar
Not true. That accord was stock tails. First he tried painting just the orange, but it wasnt matched, so he said fuck it and painted the whole damn thing (including the reverse lights)
AF Bay Area Crew
