Old 04-13-2007, 03:22 PM
Smiddie Smiddie is offline
94 Grand AM quits when I try to stop
Gentlemen:
When I drive at highway speeds for a while, and I apply the brake to stop, it will kill the engine, unless I put it into neutral. I can also shift down to 2nd, then 1st to keep the engine running.
When the engine quits it starts again easily, but dies when I put it in gear. I have to give it a little gas to get moving again, but it takes a few trys to do it.
Other than that the car runs fine. The engine has been rebuilt and is in fine shape. The car is not a junker.
I want to know if this is a transmission problem or ???.
Thanks to anyone who can shed some light on this.
Smitty
Old 04-13-2007, 04:22 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 94 Grand AM quits when I try to stop
Welcome to AF !
This would most likly be the Torque Converter Clutch Solenoid or TCC that is not disengaging, typical early model GM problem.
Here is a link that has DIY directions for the TCC replacement.
How To Replace Your Torque Converter Clutch Solenoid (GM)
Hope that helps.
1999 Grand Am SS 3.4 OHV
Old 04-14-2007, 04:05 AM
xeroinfinity:
That helps a lot.
Thank You kindly
Smitty
