Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 04-13-2007, 12:59 PM
gizeye gizeye is offline
Best Simple way to remove your car paint? (for a paint job)
Whats the best way to remove car paint for primer preparation?
-water sanding sucks and not very reliable for the primer job..
-power/electrical sanding takes long but leaves the metal with a "granite-like" surface so paint cant stick on better
-i was thinking paint remover + hand sanding?? (never tried it)
-anyone know anything about acidtone (the paint will melt right off the car when it touches) [never tried it]
Old 04-13-2007, 02:11 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Re: Best Simple way to remove your car paint? (for a paint job)
It's acetone, or brake fluid.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 04-13-2007, 05:00 PM
zacremacle's Avatar
zacremacle zacremacle is offline
you dont need to remove your paint to paint your car just D.A. it with like 80 grit then prime over that. but make sure you use wax and grease remover before you prime so that there isint any dust. The only time you need to go to bare metal is if your paint is peeling or cracked. and if you are using filler instead of glaze coat.
Old 04-13-2007, 05:53 PM
You will need to sand with another grit then 80 before primering.
-Jonathan
Montreal, Canada
Old 04-13-2007, 06:30 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
minimum grit for primer should be 180... otherwise you will get swirl marks and sand scratch swelling... and dont skimp on the prep work cuz if you do it could make your final product look like shit.. i say just bring it to a professional to paint it if you really dont know what your doing and want a professional job.. if your just looking to learn keep asking here and ill try my best to get you answers in a timely manner... or im sure people here that have painted cars will help as well.. but dont look for a A-1 job.. GL
Old 04-13-2007, 06:59 PM
slideways...'s Avatar
slideways... slideways... is offline
btw acetone isnt brake fluid. acetone is a chemical used in some paint thinners. it wont remove paint that well, especially if your not sanding first. random orbit power sander down to the primer, scuff the primer, but dont go down to bare metal unless theres rust and your using filler primer like stated above.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 04-13-2007, 11:22 PM
I didn't mean it's called acetone or brake fluid. I meant it's called acetone (he spelt it wrong), or he can use brake fluid. I know it's 2 completly different things.
-Jonathan
Montreal, Canada
Old 04-16-2007, 11:10 PM
zacremacle's Avatar
i just sand to 80 then use a primer surfacer and wet sand that down with 400. then seal and lay base then clear.everything that I have painted has turned out looking real good no sand scratches or anything like that.
Old 04-17-2007, 07:23 AM
Kind of a Big Deal
just a tip... primer surfacer doesnt provide moisture protection. so before you seal make sure that ALL the moisture is completly out or you may have rust/peeling problems down the road.
Old 04-26-2007, 07:28 PM
Chuki_breath Chuki_breath is offline
go to auto repair supplying store. Ask for air craft stripper. Spray on watch paint fall to earth exposing bare metal. Do not use brake fluid....do not get anything on surface with an oil base because it will cause fish eyes.
DO NOT TAKE IT TO BARE METAL IF YOUR JUST REPAINTING THE CAR. That would be the dumbest thing to do ever. Remove EVERYTHING off of car except for the major body panels. If no dent repair or any other body work is needed, then just scuff the living piss out of it with scuff pads. Prime. Wet sand. Paint. Clear coat. Wet sand. Buff. Stand back and fix your hair in reflection. Of course its not that easy plenty of other little things to do. One hint of advice would be....keep sanding. When you think your done....your not. Use a block too....you want straight panels.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 04-30-2007, 10:54 PM
perrenial151 perrenial151 is offline
use RAZOR BLADE
Old 05-01-2007, 08:24 AM
Kind of a Big Deal
umm or dont... using a razor blade is a royal pain in the ass. they always break and its very time consuming and you always end up sanding it because it never comes out perfectly smooth anyway.
