Old 04-12-2007, 09:23 PM
hi36951330 hi36951330 is offline
Smile A/C Needs Recharging
Hi all. I tried my A/C a couple of weeks ago while it was warm and it would not cool the car. I can only assume the freon is low. I saw these recharge kits at the auto stores and am thinking about recharging my system with one of those. I found what I think is the A/C connection. What I found was a black plastic cap over a schraeder valve on the driver center part of the fire wall. Is this where I would connect the recharger? Thanks.
Old 04-13-2007, 04:11 PM
dtownfb dtownfb is offline
Re: A/C Needs Recharging
Before you try to re-charge the system, what is the model year and engine in your Intrigue? Also do you have the manual or automatic climate control system? some people have reported problems with the AC that was more then the freon being low. there might be some folks that can help you.
Old 04-14-2007, 12:29 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
That should be the proper place to recharge it, keep in mind that you can overfill the system, so you should probably obtain a kit with a gauge, and then find out the correct value to charge it too, which could probably be obtained from a FSM, or perhaps AllDataDIY, or your best bet would be the dealership service dept.
What dtownfb said does have some merit though, there could be other causes, but if I was in your situation, I would start by ruling out the cheap things first, so I say go ahead and see if it needs recharged.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 04-14-2007, 11:09 AM
Thanks for the replies. I bought a recharge kit yesterday and it does have the gauge on it. I have a 1999 Intrigue and it has the automatic climate control system. That's the one where you can set the temperature and it will maintain it, correct?
If it evers warms up again, I will recharge and let you know what I find. Thanks again.
Tom
Old 04-15-2007, 04:52 PM
Rolm's Avatar
Rolm Rolm is offline
Before you re-charge the A/C you must find the leakfirst, no point in killing our air. Here in Canada it is ilegal to sell A/C re-charge kits. The leak must be fixed before any freon is added
Old 04-16-2007, 01:03 AM
LittleHoov's Avatar
Meh it might not even need recharging, thats why he bought the one with the gauge remember? I say if it fixes it, then go for it. I think the air will be just fine, everytime you and I exhale we kill a little bit of the air, I for one am not going to stop breathing though.
I really didnt know it was illegal to sell recharge kits in Canada...crazy. Gotta love the good ol US of A.
Old 04-17-2007, 06:32 PM
First of all, I bought one of those recharge kits at the auto store. Unfortunately it does not fit the low pressure fitting. Anyone else have this problem?
Secondly, I thought the reason the automotive people went to the 134R cooling was to get away from R-12 which was the culprit in the ozone. Makes no sense they would replace one ozone depleter with another. I think 134R is safe IMHO.
Old 04-18-2007, 06:49 PM
Thumbs up Re: A/C Needs Recharging
I took the recharger kit back to the auto store and told them it would not fit my a/c fitting. They took it to my car and tried and agreed. They brought another out and it connected easily. They gave me the new one and I left. Simple solution but it took two days to figure out. Thanks for all of the replies.
Tom
Old 04-30-2007, 11:38 PM
phewop118 phewop118 is offline
Did you ever get to recharge your system? Any potential problems I should look for when I try to do mine?
