Old 04-12-2007, 05:39 PM
Decipha Decipha is offline
rear wheel bearing
im trying to change the rear wheel bearings on a 96 3800 base model camaro, i have the chilton book and it says to remove the bolt holding the pinion shaft to release the axles, well i took the diff cover off and the pinion shaft doesn't have a BOLT! it looks to be pressed in but doesn't have any access points... I'm kind of lost right now.. if anyone knows how to remove the rear axles I'd be greatly appreciated... thanks alot all.
Old 04-12-2007, 06:23 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: rear wheel bearing
There is a bolt.
May have to turn the wheels to see it. At first, I didn't see it either.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-12-2007, 11:14 PM
alright i'll give it another look hopefully i mis-looked it
Old 04-13-2007, 02:05 AM
i donno i looked again all i see is a litty bitty bolt at the bottom looks to be maybe an 8mm bolt? thats not it is it?
Old 04-13-2007, 07:16 AM
Mr. Luos's Avatar
Firebird Guy
It has been a while.
I can check my 10 bolt sitting on the garage floor when I get home. But mine bolt isn't in there.
Maybe this will help.
With the caliper out of the way, the rotors pull off if you didn’t forget to release your e-brake. To remove the backing plate the axle will need to come out first. Remove the rear cover and let the fluid drain into a receptacle. Rotate the carrier until you see a small 8mm bolt. Depending on your car, it will either have a Torsen rear end (identifiable by the paddle) or an Auburn (which uses an axle pin). Either will slide out when the bolt is removed. If you have a car with ASR, you will need to remove the rear speed sensors from the backing plate, each held on with a 10mm bolt. Then push each axle towards the middle of the car and the c-clip should jingle jangle to the bottom of the housing. After that, the axles can be pulled out.
Stock'ish'
Old 04-13-2007, 04:31 PM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
Heh, those rear wheel bearings can be barrels of fun. My dad was driving his 67 down the interstate when he had one go bad causing his rear wheel driver side wheel to come off and pass him.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 04-14-2007, 10:18 AM
well i just changed them out... i don't see how one going bad could cause the wheel to come off?? long as the c-clip is in it shouldn't pull out
Old 04-14-2007, 01:55 PM
job complete cuz im that fukin good
Old 04-14-2007, 06:01 PM
swennc swennc is offline
Its sound like you had fun on this one! I was ready to reply a post on this to help as I had just changed mine on a '95 Base 3.4 Camaro. From your 1st post I would not guess you would have it complete all ready!!!! DAm@#$%! That is good!!
Old 04-15-2007, 07:29 PM
its not just damm good its damm fukin good
