Old 04-12-2007, 03:38 PM
tlj1288 tlj1288 is offline
97 lumina: I need help taking the factory radio out
my factory radio is a piece of crap that picks up very little reception and im looking into buying a cd player for my lumina. until then however i dont know exactly how to take the radio out because there are no visible screws or anything. if someone could help me that would be great thank you
-tay
Old 04-12-2007, 06:24 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
Re: 97 lumina: I need help taking the factory radio out
Welcome to AF!!! Well first you've got to remove the "trim plate" or bezel. On the newer (95-up) luminas, I believe it's all one piece from the headlight switch clear over to the stereo/climate controls. The bezel is held on by retaining clips which will give, you simply pull the bezel off using a bit of force. With the bezel off you'll see the screws that hold the radio in the dash. After removing the screws the radio should pull out. Of course it's still connected to speaker, antenna, and ground wires.
This ain't your grandma's car!!
Old 04-13-2007, 12:12 PM
thank u i appreciate ur help
Old 04-13-2007, 09:33 PM
sunster sunster is offline
gw84 is correct. I also needed to have the tilt steering all the way down and put the car in first gear to get the coloum shifter out of the way to get the bezel out. Of course that is if you have a column shifter.
Hope this helps,
Sunny
