Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-12-2007, 12:21 PM
hicks10 hicks10 is offline
whats better abt the 6bolt motor then the 7bolt?
I see that alot of ppl change out there 7 bolt motor for a 6 bolt motor. and what is better abt it?
Old 04-12-2007, 12:29 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: whats better abt the 6bolt motor then the 7bolt?
7bolt are more efficent, 6bolts are stronger.. both will hold 400+ hp stock.. Check the 1000 allready answerd questions ""Newbie FAQ"
Welcome to AF.com.
EDIT: Huh, seems to be down. Try Vfaq for more info on stuff. And, Give the seach feature a try. This forum is old, and there is massive amounts of info here. Good luck.
DSM geek
Old 04-12-2007, 12:30 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
The best reason is because most of us have had our 7 bolts crankwalk on us... Now some have gone and rebuilt their motors only to have them crankwalk again within 600 miles... Some of us would rather not risk the crankwalk again, so we swap over to 6 bolt motors which have never crankwalked...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-12-2007, 12:38 PM
Stop... Everything crankwalks. It's just more common in 7bolts. Don't be giving a noob the "7bolt crank walk" speech.. It's still pretty rare, even though its happend to several of you a couple times. You run a higher chance of detination problems causing your block to fail then a thrust bearing failiar..
DSM geek
Old 04-12-2007, 12:53 PM
Ok, how many 6 bolts have we seen crankwalk then?...
And you cannot say that crankwalk is rare in 7 bolts when it appears to be happening more often all the time...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-12-2007, 01:04 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
As these 7 bolt motors are getting older and have higher mileages on them, it's happening more. It can happen to ANY motor, but it's more common in the 7-bolt. It's rare considering how many Eclipses/Talons there are with them in, but it's better to be safe then sorry, espeically if you plan on modding.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-12-2007, 01:18 PM
I guess we will agree to dissagree. I'm so tired of hearing the same "7bolt crankwalk" story over and over and over. It's prodominent in 7bolt's, and it happens to lots of people, the 6bolt are less likely for it to happen, but it does happen with the Pre 4/91 model engines too.
I have no foot to stand on with this assumption, but for discussion's sake consider the following
90-4/91 6bolt engines = roughly 16months of production ( I don't know the actuall # of cars produced)
5/91 -99 7bolt engines = 84 + months of production.
There are ALOT more 7bolts then 6bolts out there. I'm agreeing that the design of the 7bolt is more sucessable to thrust bearing failier, But 6bolts have walked. It's just very, very uncommon. Take the amount of cases of 7bolt walks and divide that by the raio of 7bolt/6bolt's and you have "real data".
DSM geek
Old 04-12-2007, 01:20 PM
ok so do u think before i even put any money into a 7 bolt i should put a 6 in or stay with the 7
Old 04-12-2007, 01:22 PM
stay with 7bolt untill you have a "reason" not to do so.. Lots and lots, and lots of people have made 400+WHP from 7bolts. Which will keep you bussy for a long time before making it to that point..
DSM geek
Old 04-12-2007, 01:23 PM
I will agree with that. I had no intentions of doing a 6 bolt swap until my motor crankwalked. Then I decided not to even risk a 2nd time around with it.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-12-2007, 02:01 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Why not swap a 7-bolt into a 1G then...
j/k you guys
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 04-12-2007, 02:38 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Yep, I couldnt agree more. The only time a swap would be worthwhile, imo, is when your current motor says bye-bye. Be it crankwalk or anything else. Till then, youre good to go with what you have.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 04-12-2007, 04:14 PM
ok so my gst is totally stock what should be the first few things i should do to it to get more power?
Old 04-12-2007, 05:27 PM
thunderchicken2 thunderchicken2 is offline
Better do some research before you ask that type of questions, or the guys on this forum will own you. There are tons and tons of guides on modding, and make sure to check out Vfaq.com. It has a step-by-step on where to go with you car, and they have all your questions answered somewhere on that site. Just search around bro, that's the best way to go.
2004 Dodge SRT-4
- K&N Ram Air Intake
- AGP wg
- HKS SSQ BOV
- AEM UEGO wideband
- stock boost gauge
- Full 3" custom exhaust w/ Magnaflow muffler
- Rerouted vaccuum lines
Old 04-12-2007, 06:11 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Read.
http://www.dsmtuners.com/sub.php?page=2gtupgrades
95 Talon TSI AWD
97 Eclipse GST
