computer codes on 89 jeep cherokee
Im wondering if there are computer codes on an 89 jeep cherokee. If so, how do I find them. There is something drastically wrong with my EGR system and i am trying to resolve it. Currently i am being told the computer is not sending signal to the silinoid that controls the vacuum to the EGR to open the ports at 15mph so my NOx levels are about 3000 at 15mph and about 1500 at 25mph. Any help would be greatly appreciated.
Re: computer codes on 89 jeep cherokee
ign on-off-on-off-on, count flashes
Thanks, but where would the codes be flashing at? im assuming the computer, but where is the computer located to see the light?
Check engine light will flash. Get repair manual from library
On an 89 , you cannot do the ignition thing and count the lights to get the codes.
You have to have a special reader called a DRBII. About the only place you can find one is on e-bay, but they are expensive. Other than that, you can try to find a shop that has the correct reader. |
Here is the tool........................................
![]() Price....$3,6500......
WOULDN'T IT BE NICE..IF WHEN WE SCREWED UP..TO JUST HIT..CLT...ALT..AND START ALL OVER AGAIN
still one too many 0's!
Trouble codes are ok and all, but they're no match for a volt-meter ![]() and a factory service manual (FSM) ![]() $120.00 total USD. Learning how to troubleshoot is the key friends. ~Good Luck! |
You can even hold off on the FSM for a while by going here.
http://www.lunghd.com/Tech_Articles/...iagnostics.htm Renix based engines do not store codes. You have to check each sensor individually. the link above describes how. You can do it with a decent but reasonalbly cheap DVOM. The DRB-II has connectors that plug into the break out boxes under the yellow caps in the engine bay aft of the battery. (Well they're yellow on my '88). Last edited by Saudade; 04-22-2007 at 09:21 AM. |
take it to auto zone they do it free.
