Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 04-11-2007, 11:28 PM
Sir_David_P Sir_David_P is offline
i got a problem
i recently got a 94 JettaIII GL from the landlord but the work thats needed is rather small but the thing is one of the parts i may need i cannot find, i need a Rocker Arm cause by what was said is that the rocker arm thats in the engine right now is cracked/broken so i need to find a new one and i been searching for 3 days for one but no luck , only thing i was able to find was the water pump and oil pump that needs to be replaced.
if anyone got a place i can check out for a jetta rocker arm plz it will be highly appreciated.
Thank you,
David
Old 04-24-2007, 02:23 PM
Doug Tatham Doug Tatham is offline
Re: i got a problem
If you mean cam follower, try sasponline.com they have one for around $7.00.
If it's making a lot of valve noise on start up that stops after it warms up, this is normal. So far as I know, all the Jetta 88 + have hydrolic lifters.
