Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-11-2007, 09:56 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Question traction control problem
I have a '97 Aurora, that I have had for a year, and 9 months. Since I have owed it, the traction control in this car, has never worked, . I have read quite a lot of posts on this problem. I have only noticed one solution. Where someone paid out a cool $$$ thousand to troubleshoot his system, and then replace his (BPMV)Brake Pressure Modulator Valve Assembly,Ouch! 99% of the time, if I turn the traction control off, on the console, its not a problem. But I would like to see if I can get it to function. As soon as I turn the traction control on, it starts braking the car, as if the wheels are in a skid or something. I had the car scanned at a couple of auto parts stores. But there are no DTC's. The speed sensors on the front are new. And I cleaned the ones on the rear. The previous ower ran the car hot, and a hose or something bursted, and spewed water inside the engine compartment. I'll check to see if any water got into the electronic brake control module. And check by the salvage yard to see if I can fine a used BPMV. Any suggestions would be appreciated.
Old 04-12-2007, 09:22 AM
lynzoid lynzoid is offline
Re: traction control problem
to get ABS diag errors you must use Tech2 scanner only, invoke 'chassis-EBTCM' section, and read codes. i bet there's plenty of them for you mate.
Old 04-12-2007, 09:26 AM
maxwedge maxwedge is offline
A990 racer
You can also use a Snap On MT2500.
Old 04-12-2007, 11:21 AM
is that true for 95's wedge ??
i mean i had mt2500 in my hands and i read DTC's from my 95, but i failed to spot extra unit controls in menu (chassis, DIC, etc).
Old 04-12-2007, 12:55 PM
A990 racer
When first prompted what systems you should be able to pick abs, mine does. Now you would need a trouble shooter abs cartridge to get into in depth diagnostics, but you should be
able to check wheel speed sensor inputs.
Old 04-12-2007, 02:08 PM
ah the extra cartridge.. i see... cos for me only tech2 with domestic usual cartridge showed up whole range of extra stuff, such as abs autobleed, idle cal. procedure etc... still trying to buy cheap tech1...
Old 04-14-2007, 12:56 PM
I got my abs scanned today. Had to search for a shop that had the scanner. Midas did it for $101.26. They didn't give me the DTC's, but told me the right wheel sensor went bad, and caused the anti-lock brake, traction control module to short to ground. They told me I need to replace the wheel sensor($180.52), and the ABTCM(411.66). I may not have to pay for the wheel sensor, since it came with the wheel bearing that I purchased last summer. I am sure it had at least a year's warranty on it.
That ABTCM could have been already bad before i replaced those wheel bearings and sensors. The mechanic said there was no way i could prove that.
Old 04-14-2007, 06:43 PM
rape. new wheel hub - 80$, new ebtcm - 200ish.
scan for 100 without even DTC's - rape
Old 04-14-2007, 07:16 PM
A990 racer
Exclamation Re: traction control problem
Do not do the ebcm ,this code can be falsely set by the speed sensor on many scanners.
Old 04-20-2007, 04:18 PM
I went back and cleaned my speed sensor connections, just to be sure they are clean. I installed a hub and wheel bearing assembly on the right side. Afterward I took Rora out for a drive. The traction off indicator came on, then blinked off. But the anti-lock brake indicator stayed on. After stopping at a store for a soft drink. The anti-lock brake indicator blinked off. The next day I took Rora out for a 30 mile trip, and came back and drove around town awhile. I didn't have a problem with the traction control. Rora's ABS is up and running. I didn't have to bother with the EBTC module.
Thanks guys! I think I saved enough money to enjoy a steak dinner and a 16oz brewski.
Old 04-20-2007, 05:35 PM
here in cold russia-ski iski will haveski to getski byski on pizzaski =)
glad it helped. get it scanned anyway when you have a moment
Old 04-21-2007, 11:55 AM
I was looking at snap-on MT2500 scanners on e-bay. Some comes in a set. And others are just the main controller. Then there is just the accessories: cartridges, adapters, cables, manuals, and keys. what are the basic items that I need to troubleshoot Rora?
Old 04-21-2007, 12:00 PM
Quoting one snap-one technician, to scan my 95's basic DTC's i need:
Scanner
Main Cable
OBDII adapter
Key 9
95 or newer domestic primary cartridge
Also as i understand, to get EBTCM DTC's i will also need a ABS troubleshooter cartridge. I don't actually plan on getting one meself, as my rora's abs/tcs system is almost trouble free (excluding pmv overpressure signal dtc, which is basically needed in case i slam on brakes while traction is active only), and i have a handy repair shop that gives me tech2 to use at theirs free of charge. believe me, i've seen loads of usa oriented scantools, but tech2 blows them all away =) bit pricey tho
Old 06-20-2007, 10:14 AM
keith3196 keith3196 is offline
Pontiac GTP 1999 Diagnostic Code C0550, my dealer told me I had to replace the EBTCM for $1200. All three ABS, TCS and Cruise Control non functioning.. According to the codes I've seen listed its the ECU..
Now I'm confused.. should I get the State's fraud division involved with this dealer? So far I've had four diagnostics done to the tune of $400 and yet I've done no work because they want my first born to do the job.
They even had the audacity to tell me that the EBTCM may not be the only problem that another module may be causing that one to fail to the tune of another $800 or so!
This sounds like guess work to me at my expense.. what should I do? Both about reporting them and about my ABS/TCS/CC problem?? I don't hear any wheel noise. Is it possible that the ECU is the culprit?
Thanks...
Old 06-20-2007, 11:07 AM
offtopic. but
all you have to do is get at least alldata manual for your car, and do an EBTCM diag according to Diag FlowCharts !
Most prolly u just lost power/grounds to some components.
Or lost comms between PCM and EBTCM.
My bet is on wiring/electrical.
But even if your EBTCM is bad - you can get one off junkyard for 100ish bucks.
I'd report dealer to tradesman org.
Closed Thread
