Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 10-13-2002, 04:04 PM
roastin944 roastin944 is offline
Putting 951 engine in 944
Hello, I would really appreciate it if someone could tell me what would be involved in putting a 951 engine in a 944 NA car. What all would need to be different, the engine would go in but could the clutch and tranny be use off the 944. How about the fuel system, would i need the pressure regulaters, pumps, injectors off the turbo engine also? How about the computers, i would need a klr and probably the turbo dme. Would i also need all the other electric sensors in the engine from the turbo? Please help, Thanks
John
Old 03-28-2006, 10:26 PM
deadlyvt deadlyvt is offline
Re: Putting 951 engine in 944
I have done this install on a few 944s...its one of the more difficult engine transplants to do. First off the engine clutch and flywheel will all xfer from the turbo-non turbo cars however i would recomend a new clutch and lighter flywheel when u do the swarp (eases the strain on tranny if you arnt switchin that). you woul need the computer systems and a complete wiring harness from a turbo. The wiring harness would need to be modified to allow your lights to work...you would also have to rewire some of your fuse box relays and fuses. If you arnt knowledgable with major mechanical work I would strongly recomend you get a proffesional to do this... Also the dash would need to be rewired or else you wont get rpm and boost to show up. I can/would be able to do such a swap and or any performance modifiaction if you want...let me know your location I am the owner of MANSTEIN PERFORMANCE reach me at [email protected]
Old 08-01-2006, 04:52 AM
ridrnkink18 ridrnkink18 is offline
hello...i was wondering if anyone here could help me out...i am putting the 944 turbo motor in my stock non turbo 944...the motor is 86 and the car is 87...i know the motor will bolt right in and i have my exhaust setup and everything but theres the major things i need help with...could someone please list the major things i need to do to have that car running good as a non turbo 944 car with the turbo motor...mostly electrical...basically what extra wires are on the turbo motor that are not on the non turbo motor..i have computers and gauges and all that..should i replace my gears in the trans axle..will it hold up for a little while till i get enough money to get different gears...the electrical is the hardest part in my mind..everything else just kind of bolts up...what about speedo and tach will they work correctly? i live in bridgewater, nj i have a stock 944 motor for free if anyone is interested in helping me out..please let me know...908 304 8382
