Old 04-11-2007, 07:59 PM
youngcaradvc youngcaradvc is offline
Fuse Box
I think I have found the fuse box near the brake pedal, it has the colored boxes that look like buttons correct? Anyway my real question is where is the diagonstic connector? So that I can hook up my multimeter and find out whats wrong with my tranny. I think I found it, I found one of those plastic caps just hanging down there that matched up with the DSM diagram but I am not 100 percent sure. One more question, I have been reading a lot on the "N/A Bible" by Yogurt on 3si and I was just wondering if all those horsepower gains and 1/4 times are correct, just based off of your personal knowledge and experience is enough, thanks.
Old 04-11-2007, 08:54 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Fuse Box
yes, the diagnostic connector is to the right of the fuse box
the TCU codes can be found here.
as for the NA upgrade bible, i haven't looked at it in a while, but i'm pretty sure those hp and ET estimates are accurate.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-11-2007, 09:18 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Fuse Box
The diagnostic connector is right next to the fise box on 1g's. However on 94-99 the connector is above your right knee if you are sitting in the seat.
Old 04-11-2007, 11:18 PM
Linebckr49's Avatar
Re: Fuse Box
good to know! learn something new everyday.
93 3000GT base
Old 04-11-2007, 11:24 PM
Re: Fuse Box
alright thanks, yeah i was using that DSM link as a guide but it wasnt exactly the same on my car, my port was hanging, not attached to anything, it had wires and was held together further above with electrical tape bunched together with the other groups of wires. thanks
Old 04-11-2007, 11:29 PM
Stealthee's Avatar
Re: Fuse Box
On my Talon I went to pull codes the one day and couldnt find the diagnostic port. I was like WTF.... after massive searching I finally found it tucked behind the fuse box. Why it was pulled off I dunno. It just slides onto the fuse box and locks in place.
Old 04-12-2007, 09:43 AM
Igovert500's Avatar
blue + red light magnet
Re: Fuse Box
Any times, hp gains etc, are always just estimates. Alot depends on how your car is running, and how you are as a driver.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-12-2007, 10:23 PM
Re: Fuse Box
Well considering im ATX, most of the shifting is done by the car . Anyway I pulled out the code today, 61. Torque Reduction signal line, this makes sense since Mr. Transmission pulled out codes from the ECU and got one that read: 61 ELC-4AT (torque reduction). Thanks for the help, kudos to linebckr49 for always replying to my posts.
