Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 04-11-2007, 07:58 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
96 2.0 no Start
I just replaced an oil pan on a 96 Dodge Neon 2.0L. The owner ran over a huge rock and put a hole in the pan the size of a dime. Well before I even replaced the OIL PAN I check to make sure the engine wasn't locked up and cranked the engine for a few second, never started. So I went ahead and replaced the oil pan, refill it with oil, and tried to start it still engine spins fine but will not start won't even make a hint of trying to start, check the timing belt to see if it is spinning, it was spinning also, but I am not getting NO SPARK at all, the injectors are opening (strong smell of fuel when cranking engine).
What do you guys think the problem could be.
Any and all suggestions appreciated...
Thank you
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 04-12-2007, 07:13 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 96 2.0 no Start
Keep it simple at first and check all fuses and relays. Did you check for spark at the coil pack?
2003 Dodge SRT-4
Old 04-12-2007, 09:38 AM
Bear Bear is offline
Re: 96 2.0 no Start
On my '98 it was a crankshft position sensor that failed and gave me a no start condition. Have you tried to key code the car and see if any codes pop up? Try to code and tell us what you get, Auto Zone will code for free but you need to get it there.
Old 04-12-2007, 04:23 PM
denisond3 denisond3 is offline
Re: 96 2.0 no Start
I recently bought a new cam position sensor assembly for our Neon, and it cost less than $30. So if that is looking cracked, its not financially ruinous. I would also suspect some of the wiring harness connections of having been cracked or sprung loose. The speedsensor connection and crankshaft position sensors are behind the engine, and hard to see.
Please let us know what you find....
