Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 04-11-2007, 07:28 PM   #1
hotrdchevy85
Angry 2000 lumina smell antifreeze
i just bought this car today .and when you crank the car and open the hood you can smell antifreeze really bad ,there is none leaking on the ground and the temp gauge is fine.any one know what this might be from?any info would help thanks
hotrdchevy85 is offline   Reply With Quote
Old 04-11-2007, 07:33 PM   #2
maxwedge
A990 racer
Re: 2000 lumina smell antifreeze
Welcome to AF. Lots of possibilites here particularly the troublesome lower intake gaskets common on these engines. Check for signs of coolant contamination in the oil, inside the oil filler cap and get it pressure tested, may be a small leak that will only show up during a pressure test.
maxwedge is offline   Reply With Quote
Old 04-11-2007, 07:43 PM   #3
hotrdchevy85
thanks alot i heard alot about the intake gaskets.
Old 04-13-2007, 10:39 PM   #4
sunster
Check the water pump, if the accessory belt appears greasy looking and the under hood pad is wet then your pump may have started to have a small leak.
Sunny
sunster is offline   Reply With Quote
Old 04-15-2007, 10:41 PM   #5
1993LUMINATOR
Send a message via MSN to 1993LUMINATOR
l wouldnt worry over it guy, if the fans come on the temps good and the levels are ok just live with it as l have.
another good thing would be too chek your STOCK ORGINAL METAL HEATER HOSES they often get very rusty and pop a small leak that car dry very fast and you wont notice it unless you look at your subframe when its cold or sitting cupple days and see some greenish coloured drips
1993LUMINATOR is offline   Reply With Quote
