Old 04-11-2007, 04:03 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Roof Top Antenna Installation
Anyone install an antenna on their roof? I want to but need help in figuring how to drop the headliner.
Sonny
Old 04-11-2007, 09:19 PM
FiTxAg04's Avatar
FiTxAg04 FiTxAg04 is offline
Re: Roof Top Antenna Installation
What type of antenna? Sat. Rad?
2004 Chevy z71
BF Goodrich T/A KO 285/75/16s. Flowmaster 40 Series exhaust. K&N intake. Stull billet grille. F-150 torsion bar index keys. 800w stereo system.
Old 04-11-2007, 10:27 PM
vnotaro vnotaro is offline
Enough support up there? Or will it buckle the sheet metal? I could be wrong, but it seems like it's a little bit too thin up on top.
Old 04-12-2007, 02:27 AM
Sonny01's Avatar
It's a 2 meter/70cm ham antenna. And it's pretty big, 40" high.
http://www.universal-radio.com/catal...antm/3907.html
Old 04-12-2007, 05:15 PM
rjeffery rjeffery is offline
We installed something like that on my buddy's truck. We installed it at the front of the bed on a bracket. You might want to consider doing that, then you don't have to drill on the roof, and you don't have to have a 40" antenna on the top of your truck.
Old 04-12-2007, 06:19 PM
Sonny01's Avatar
That sounds like a great idea...thank you very much!
Now I have another question...how do you get the overhead console down to mount a control head inside it?
Old 04-13-2007, 10:22 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
there should be 1 phillips screw on the bottom towards the windshield and then just pull down and i will unsnap. they are tough clips may need to pull hard if gently pulling doesnt work
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 04-13-2007, 12:39 PM
Sonny01's Avatar
Thanks sportin83...it came down real easy!
Old 04-19-2007, 09:52 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I do this all the time. Remove the clothes hooks and if you can, remove the interior light assembly. You'll thank yourself later. Just drill the hole in the roof, drop the interior light to get the coax started where you can access it good, and then after removing the laundry hooks pull slightly on the headliner. Its held in place with small velcro strips and will drop down so you can run the rest of the coax. Any more ?'s just ask. I do this at least 2 times a week mounting 2'way antennas.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-20-2007, 08:02 PM
Sonny01's Avatar
I chickened out and went with a lip mount and a shorter antenna. The second picture is the control head.
