Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-11-2007, 03:53 PM
civic542 civic542 is offline
Question Throttle body?
I read in a book called "Civic Duty" that you can take the 65mm throttle body out of a 5.0 Mustang and put it in a civic. First off is this true? And second, if it is, does it matter what year model of the Mustang it comes out of? Thanks a bunch!
if it hurts, hit it til it stops hurting
Old 04-11-2007, 05:20 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Throttle body?
do you have any kind of modification to justify this? I've thought about upgrading a 68mm TB eventually and i'm going to be in the mid 300whp range
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 04-11-2007, 05:21 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Throttle body?
Yes it is true, but I believe you need an adapter plate for it to fit onto a honda or acura intake manifold. No clue what year mustang either. But it really won't do you any good unless you have the mods to need a bigger throttle body, and a big enough hole in intake manifold (65mm) to make use of it for other mods.
Old 04-12-2007, 06:49 AM
alfonso2501 alfonso2501 is offline
Send a message via AIM to alfonso2501
Re: Throttle body?
Or you can just use a throttle body from a different Honda/Acura thus eliminating the need for any special adapters.
What type of mods have you done to the car?
Old 04-12-2007, 07:40 AM
Schister66's Avatar
AF -Advisor
Re: Throttle body?
i've seen people snag an H22 throttle body and use it on various D series...B series on D series engines and so forth......your best bet since you dont sound like you have a lot of stuff done to the car is to find a larger OEM Honda replacement...
Old 04-13-2007, 03:10 PM
Re: Throttle body?
No, I really haven't done much at all to my engine due to lack of money, but I'm planning on rebuilding the engine with perfomace parts and maybe throwing in some boost too. Thanks for the help!
Old 04-15-2007, 12:35 PM
Schister66's Avatar
AF -Advisor
Re: Throttle body?
Originally Posted by civic542
lack of money
Those are two phrases that dont go together. If you dont have money, dont waste what little you may have turboing your car. Contrary to popular thought, it isn't easy or cheap. Building a turbo Honda, although fun and exciting, takes a lot of time, effort and money. I'm not in any way telling you not to do it, but if you plan to, make sure that you have $5k saved up...even if your setup would cost $3500...it is expensive and things DO break...
Old 04-16-2007, 02:20 PM
Re: Throttle body?
Oh, believe me I know how expensive and time consuming it is, but not planning on doing it next week either. This is an over the next couple of years thing. I'm just trying to plan ahead and get stuff straitened out before then. Thanks for the help! I think I might just stick with Honda and maybe go with one off an h22 or something. Anything beats a ford, haha.
