Old 04-11-2007, 06:41 AM
cavasinj cavasinj is offline
Ford I-6
I am looking to buy an older work truck/hauler. I have read that the old I-6 Ford made in the early 90's was a solid engine, and usually helped make any pickup with it quite a reliable purchase. As I have been researching I have seen several 6 cylinder Fords listed as a 4.9L. Is that the correct/right engine size? Is there any truth to the thought that this is one of the better engines Ford made?
Thanks
Joe
Old 04-13-2007, 12:36 AM
Torch Torch is offline
Re: Ford I-6
4.9 liter sounds right, 300CID is a common straight six (I-6) engine size, 5.0 liter = 302CID, so again, it sounds right.
Straight six engines have been well known for their reliability and are (in general) very easy to work on, I personally don't know anything about this engine but I wouldn't think you would have any problems with it.
Suzuki has been reintroducing the straight six engine in some of its cars which is saying something about the I-6 engine when they choose to go with it instead of the more popular V-6 design.
I-6 engines are known for being torque-y in regards to hauling things, they take a while to get up to speed but they will get you and your load you where want to go.
Some things to watch out for on I-6 engines, the center cylinders tend to run hotter than the outer cylinders, pull the plugs and check for contamination or sludge on the plugs. Do a compression check and check for head gasket leaks between the cylinders, other than that the valve covers tend to leak after a while if they have cork gaskets on them.
Old 04-14-2007, 10:38 AM
wafrederick wafrederick is offline
Banned
Re: Ford I-6
Yes it is reliable.My father's clean up guy who also takes care of the scrap metal that has one close to 300,000 miles on it and it is a 1991 2wd.This one is beat up and it all it does haul scrap metal.
Old 04-14-2007, 01:30 PM
89Firebird2.8's Avatar
89Firebird2.8 89Firebird2.8 is offline
Re: Ford I-6
Thing is, isn't the 4.9 only available in the half-ton? half-tons have never been my first choice for hauling.
2012 Ford Fusion SE 3.0 V6
-SOLD- 1992 Lexus LS400 4.0L V8
-SOLD-1989 Firebird 2.8l V6 Red and White w/flames. Stock. Daily Driver.
Old 04-14-2007, 07:04 PM
butch h butch h is offline
Re: Ford I-6
Some of the older F 250's had the six cylinder,mostly two wheel drive,but I know of one 4x4 manual transmission.
Old 04-14-2007, 07:48 PM
scoopy03 scoopy03 is offline
Re: Ford I-6
Originally Posted by Torch
4.9 liter sounds right, 300CID is a common straight six (I-6) engine size, 5.0 liter = 302CID, ------> (true but really a 305 is 5.0 302 = 4.9 but it is easier to just call it 5.0 ) so again, it sounds right.
they do tend to get mad sloppy with the valve cover leaks
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
Old 04-15-2007, 10:40 PM
ken0001 ken0001 is offline
Re: Ford I-6
I have an 88 F250 with the I6 engine, its has a 5 speed manual tranny, and is indeed made for pulling!!!
Great engine.
1999 Alero 2.4L I4
1988 Ford F 250 4.9L I6
