Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 04-11-2007, 03:09 AM
fusion27 fusion27 is offline
Question need help with my airbag light
My airbag light flashes (#42), and remains on, can anyone help, its a 2003 Expedition 5.4
Thanx,
Roy
Old 04-11-2007, 12:22 PM
reekor reekor is offline
Re: need help with my airbag light
I don't like giving too much info on air bag systems, because they can be very dangerous and can cause a lot of money in damage if mishandled.
Disconnect the truck’s battery and wait 5 minutes for the backup power supply to deplete in the SRS.
Clean surface/thighten bolt under the "front impact severity sensor". Located at the bottom of the hood latch support bracket.
If that does not fix the problem, seek help as you may need a new sensor or other SRS repairs to be done.
Thanx,
Roy
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-13-2007, 03:55 AM
Thanx for the help, i disconnect the battery for about 5 mins and the light went away.
Old 04-13-2007, 03:59 AM
Thanx for the help, I disconnect the battery for about 5 mins, connect it back and the SRS light went away.
