Old 04-11-2007, 12:21 AM
scoopy03 scoopy03 is offline
84 mustang 5.0+drag lite 15X14
I wondering how to go about tucking drag lites on a 84 mustang. i heard you have to take out the upper shocks in the rear. do you need lower control arms? the mustang already has c. adjustables.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
Old 04-11-2007, 10:38 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: 84 mustang 5.0+drag lite 15X14
15x14 is a wide wheel. To "tuck" that much wheel/tire you are looking at alot of work. Yes you will have to remove the top shock.
What do you mean by c. adjustables?
To need a 15x14 wheel I guess you are gonna run huge tires? You will have to tub the car and narrow the rear. To help you choose the best parts for your application I need to know more about your combo. How much power are you making? Or do you just want that drag car look? I would suggest Strange axels, 9" ends (if useing 8.8 rear), differential or spool with the same spline count as the axels, and of course a fresh set of gears with a ratio of your choice. The spline count you choose will depend on the power/torque you are making. If this is a street car then I would suggest you stay away from a spool, get a Strange pro-posi unit (its limited slip but will spin both tires evenly when you punch it). Also the rear gear you choose will depend on the tire you wish to run as well as the rpms you plan on turning. Last but not least you have a choice to make with the 9" ends as well. When you weld 9" ends to an 8.8 rear you are replacing the stock C-clip style ends. But you have big 9" ends and small 9" ends to choose from. If you plan on running a "race" style rear disk (again Strange makes awsome rear disk brakes that are light weight too) then you can use the big ends. If you want to run stock style rear drum brakes or upgrade to the rear disk brakes offered by SVO then you need to use the small 9" end.
You may very well have to run an offset lower control arm. I would also suggest that you run an adjustable upper control arm. Team Z and Wolfe Race Craft offer great parts. I have Team Z suspension on my car with a Wolfe 10-point cage. Give Dave at Team Z a call 734-789-9540. He can go over everything with you and get you the parts you need at a competitive price.
There are alot of variables as you can see. There is no bolt up and go to "tuck" wheels this big with the correct size tire for the application.
1969 Cougar
357w & TKO - 475hp
Old 04-11-2007, 02:16 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
You don't have to tub, you can always go out, like I am doing.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 04-11-2007, 02:26 PM
351wStang's Avatar
14" wide on a fox, that would leave like 6" sticking out of the wheel well. LOL open wheel mustang.
1969 Cougar
357w & TKO - 475hp
Old 04-12-2007, 03:59 PM
c adjustables = coney adjustables (i cant spell it right)
Old 04-12-2007, 04:20 PM
SkylineUSA's Avatar
Do you mean Koni?
David,
8" is all that can fit in your wheel well? Are you sure about that? I had 10" wide on my Fox without any clearance issues. Plus wide bodies are the way of the new world order
Old 04-12-2007, 08:38 PM
Originally Posted by SkylineUSA
Do you mean Koni?
David,
yes koni adjustables
Old 04-13-2007, 01:02 AM
351wStang's Avatar
David,
I could fit 10" wheels fine but they would have a 1/2" or so hanging out I think. Gonna save the bullet proof 8.8, mini-tub, 325/50-15 project for this winter. Its time to drive this thing!
1969 Cougar
357w & TKO - 475hp
Old 04-14-2007, 08:51 PM
so with 10" or 12" what would have to been done?
Old 04-14-2007, 10:06 PM
351wStang's Avatar
With a 10" wide wheel and a 6.5" backspace you could run a 275/50-15 and do some hammering to the inner wheel wells and be fine. Or you could run say a 275/60-15 and hammer the inner wheel wells as well as roll the fender lip and be fine.
What are you trying to acheive here? Do you just want that big tire look for your car? I'll get a pick of my car from the back if you like.
1969 Cougar
357w & TKO - 475hp
Old 04-16-2007, 12:20 AM
looking for big tire look without having to go too far in changing things in the back pictures would be fine.
Old 04-16-2007, 10:20 AM
351wStang's Avatar
The widest you can go without rubbing and without major work to prevent rubbing in the back is a 275/50-15. Mickey Thompson ET street radials tend to be a little wider than BFG drag radials. For the 275/50-15 you can go with an 8" - 10" wide rim. I have 8" wide Weld drag lites on my car and from the side they give a little deeper look. The 10" rim would give a more squared off look on the side of the tire. With the 275/50 you will have to remove the top shock and hammer in the inner fender area some. You wont be able to tell it was hammered unless you look inside the wheel well. I'll try to get a pic up from the back of my car for refference.
1969 Cougar
357w & TKO - 475hp
Old 04-16-2007, 10:25 AM
351wStang's Avatar
This isnt a pic from the back but it shows the front tire pretty good. See how the from tire is kind of squared off with the rim? Sort of flush down the side? Thats close to what the 275/50 would look like on a 10" rim. You can see the back tire decent in this pic. It doesnt really show how wide it is but you can see how it looks "deeper" than the front. The 275/50-15 tire is 26" tall, and about a foot wide. These are directional tires.
Hope this helps some. I'll try to get a better pic up soon.
the front is sitting so high in this pic because the motor wasnt in when I took the pic.
1969 Cougar
357w & TKO - 475hp
Old 04-16-2007, 11:20 AM
TheStang00's Avatar
TheStang00 TheStang00 is offline
i just feel compelled to comment, that you fox is a beautiful thing.
Old 04-17-2007, 09:04 AM
351wStang's Avatar
Thanks! Check out the "Latest progress on my street car." thread for more pics details. I got the camera again today for new updated pics.
1969 Cougar
357w & TKO - 475hp
