Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-10-2007, 10:22 PM
99 shortbox sierra 99 shortbox sierra is offline
Angry HELP bottom end power loss
99 sierra 5.3 auto, if over 1/4 pedal acceleration, engine bogs and barely accellerates. If you ease onto the throttle, it accelerates fine. Tried running gears individually and used tow mode, no change. New fuel pump, msd 8.5 superconductor wires, iridium plugs, battery, and transmission, no change. Got it scanned, random misfire code appears. Told possible air leak but can't find one. I was told that the 5.3 has lots of power, but mine can't even spin 33's in mud. Seems to get a little better when warmed up but still acts up. Going to try fuel filter and regulator next, but gettin sick of throwin money at it and seeing no change. Any help is GREATLY appreciated.
Old 04-11-2007, 06:07 AM
MyTOY's Avatar
MyTOY MyTOY is offline
Re: HELP bottom end power loss
fuel filter? That should have been replaced with the pump and is
usually the first thing people replace when having a prob. like this.
I've also seen folks with bad cats. have this sympton. good luck
03 WRX
Old 04-11-2007, 05:51 PM
Fuel filter makes no sense though, at idle it revs fine and doesn't miss a beat, also starts fine, i was guessing at the MAP sensor or the MAF sensor.
Old 04-12-2007, 11:47 PM
plnuout plnuout is offline
Exclamation Re: HELP bottom end power loss
I think i know what may be going on, do you have a k&n air filter, or any other kind of aftermarket airfilter with any kind of light oil on it?, if so you may have got a little bit of oil on your map sensor, which a diagnosic tool will not detect. I went through about $ 1100 trying to figure out what was wrong and all it takes is a $2 can of friggin carb cleaner to the map sensor. After you spray down your map sensor it may still be boggy but drive around for a while and it may fix your problem like it did mine. Good Luck
PLNUOUT
Billings MT
Old 04-13-2007, 12:29 AM
Low-Low-SIERRA Low-Low-SIERRA is offline
Hey bro I had the same problem a couple months ago. I ended up spending like $800 bucks and nothing. What ended up being the problem was the Catylic converter it was pluged up and that also ran me like $300 bucks for a dyno.
My truck did the same exact thing you are describing.
Old 04-15-2007, 09:13 AM
Regalwhiskey's Avatar
Regalwhiskey Regalwhiskey is offline
Perhaps the computer can't handle the tire size. Has the Torque gone south and you need lower gear ratio's?
Old 04-15-2007, 12:13 PM
how many miles or kilometers were on your when the cat plugged up?
