auto tranny service
I'm definitely dropping both pans. I've heard before that the filters can be cleaned out and reused. I think I'm leaning that way. Any good reason not to? I think I've seen 2eye recommend reusing the filter for the main valve body. This will be my first look at the filter for the overdrive valve body - wonder if it can simply be cleaned and reused. I want to do this once! Thanks.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2 1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs 1996 VW Jetta GLS 2.0L 5 spd |
Re: auto tranny service
On the other hand, a hundred kicks for the gaskets AND filters beats a few thousand for another 4L-30E...
Search the FAQ's for some photos of what a tranny filter looks like after 80k with tranny flushes.
-Ryan Isuzu Moderator Car Show Tips Operations manager with a results-driven passion for process improvement FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd |
"What did the filter look like after 85K and yearly flushes on a 99?
It was full of contaminants... metal sludge (akin to a aluminum paste). No chunks of metal, just sludge, again with the paste... thick and gooey, like aluminum colored mud."
Good enough. Thanks!
That was ugly. Mine has never looked like that!
maintenance preferences.like why even take the chance? or are you just looking for some discussion? //bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
Change them out Surfer, BIG difference when that little pan gets dropped too.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
EDIT: $123 from St. Charles. I'll post pics when I do it. Kinda curious to see the bottom of the overdrive pan...
Mine, even at 171k miles doesn't shift a day over 30k miles, from the way you've talked in the past, I'm guessing your's feels the same. Keep driving/changing the fluid, I'm sure it'll go a few more years yet, as long as your daughter's not too rough on it. My tranny - with living in the highcountry, running bigger tires, and pulling heavy loads most of it's life - has had it rougher then yours with living in the flat-land; you'll be fine. Don't JINX it!!
I'm going by other's experiences and Murphy's Law! The trans is shifting as well as the day I bought it and it was treated with kid gloves until the daughter got her license last June. 161K and counting.
edit add:: in fact, post some pictures of the setup you use to do the job without getting the whole garage floor a nice red/pink color .... //bc
Lots of rags!
Are you guys serious? The gaskets are that high. I was thinking of dropping my pan, but expensive gasket. What filters do I need?
2007 Chevrolet Silverado 1997 Izuzu Rodeo LS 4WD |
The gaskets aren't bad, it's the filter for the main valve body. Let me see if I can get a representative link...
http://www2.partstrain.com/products/...OD-V6-002.html
You also need the gasket and filter for the overdrive. That's another $20-$25. The filter for the overdrive is just a mesh screen. Maybe that's the one that is cleanable/reuseable...
