Old 04-10-2007, 03:54 PM
HondaManDan's Avatar
HondaManDan HondaManDan is offline
Send a message via AIM to HondaManDan
Exclamation Wheel Locking Up (ABS Light ON)
My car's ABS light has been on since I bought it over seven months ago and I havent had a problem until recently.
I noticed on wet roads, sandy roads, or in emergency-stop situations my Rear, Right brake will lock up. On slippy surfaces it barely takes any effort to do this, and it's only that wheel.
Should I replace the hub ABS bearing?
The ABS doesn't work (at least I've never noticed it working) and I don't know if it's because of this hub sensor fouling causing the whole system to not work...
Does anyone know how to check this without bringing it to a dealer?
Where do I look to see if the computer is throwing a code?
Thanks a lot!
Dan
95' Buick Park Ave... hell yeah.
Old 04-10-2007, 04:20 PM
maxwedge maxwedge is offline
A990 racer
Re: Wheel Locking Up (ABS Light ON)
You need to get this on an abs function scanner look at the codes, check comparative wheel speed inputs for a possible bad wheel speed sensor.
Old 04-10-2007, 04:33 PM
So... basically spend the 80 bucks for a dealer to check it out...
Dan
