Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2007, 02:14 PM
rob67gmc's Avatar
rob67gmc rob67gmc is offline
Torque arm/ tranny bolt
The upper bolt hole where the torque arm bolts to the tranny is stripped out. What is the best way to fix this? One friend suggested a Helicoil and another said to fill the hole with JB Weld, then drill and tap it.
Thanks,
Rob
1989 Camaro RS convertible
Engine & trans has been changed to 350 TPI w/ 6-speed manual
K&N filter
BBK 58mm Throttle Body
Richmond 3.73 gears
Spohn full length adj. torque arm
Spohn lower control arms w/ poly bushings
Spohn Adj. panhard bar w/ poly bushings
Spohn front & rear sway bars
Spohn weld-in subframe connectors
PST complete front end rebuild kit
KYB struts & shocks
Old 04-10-2007, 07:35 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Torque arm/ tranny bolt
Not sure I would fill it.
Helicoils hold well.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 04-10-2007, 08:16 PM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
jb welds not the best thing in the world..
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 04-11-2007, 12:52 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
http://www.umiperformance.com/2200?category_id=45
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 04-11-2007, 01:15 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Originally Posted by blindxeyed
AGREED!!!!
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 04-11-2007, 09:20 AM
rob67gmc's Avatar
I like the way that arm is mounted but there is not one listed for an '89. Plus, since I just bought the car last week most of my available playin' around cash is gone for right now. Hoping for a cheaper fix until I get a few more bugs worked out of the car.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 04-11-2007, 09:31 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
UMI third gen tunnel mounted torque arm hasnt been released yet... they have only made like 3 too
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 04-11-2007, 08:32 PM
Mr. Luos's Avatar
Firebird Guy
That be mine.
But mine be black.
LCA's too.
Stock'ish'
Old 04-12-2007, 01:04 AM
poly on the LCAs??? pussy!
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 04-13-2007, 07:19 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Thanks,
Rob
When i first put my 350 in my firebird, i went from a standard to an automatic. Soon after the install, the back of the transmission where the torque arm hooks to broke completely off the transmission.
If its just a bolt hole, make your own mount. You could re-thread it and use a bigger bolt also. IMHO the original ones are stupid, when mine broke it beat the crap out of the underside of my car, and then drug the street and bent the torque arm nearly in half.
heres mine, its been this way for years now, no probs. And im quite rough on it.
Old 04-16-2007, 01:18 AM
rob67gmc's Avatar
I like the idea of making the mount but the rear of my trans looks a little different than yours. I'll take a closer look and see what I can come up with. I like fabricating my own parts when I can. Probably going to make my own subframe connectors and strut tower braces.
Is your torque arm bolted directly to the mount with no bushing?
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 04-16-2007, 04:02 PM
yeah it is except a series of washers between the mount and arm to keep it from wearing out. I think i used two plastic washers with a rubber one in between if i remember right. The bolt isnt tight so it allows some movement. I check it every time i get it on a lift and it has shown no signs of probs where the arm and mount connect.
I didnt intend this car to ever be on the street or i would have made it a little different. Actually i modeled mine from one i saw somwhere else, i dont recall where if it was online or at the shop. It started to clunk last summer when i put it into "R or D" and i thought i broke the mount i made and it ended up just being the transmission mount.
The way i drive my car i figured it would let go or mess something up long before now since ive jumped railroad tracks, gone mudding ect in this car with no probs other than a few spots where i high-centered it on a rock several times in a row out at the lake.
Old 04-18-2007, 02:08 PM
rob67gmc's Avatar
Just to let everyone know, I retapped the bolt hole and it's holding for now. Probably just a matter of time before it strips again. I think I'll make a new mount as soon as I get the time. Thanks for the suggestions and pics, gave me a few ideas.
K&N filter
Richmond 3.73 gears
KYB struts & shocks
Old 04-18-2007, 06:25 PM
Cool. Maybe it will hold for a long time, you never know. I figured mine would be a temporary fix also, and its still holding.
