Old 04-10-2007, 02:10 PM
twilter twilter is offline
Electric seat problem
96 Jimmy SLT blazer - power seat quit working, just like that. Checked fuses,plugs,wire harness can't find problem. Don't think its the switches
they don't usually go in a cluster all at once. Any feedback would be appreciated.
Old 04-10-2007, 02:23 PM
slredstorm62 slredstorm62 is offline
Send a message via AIM to slredstorm62
Re: Electric seat problem
did you check the motor? and check and make sure the ground is still good becuase corrosion might have gotten into it and ruined the ground.
Old 04-10-2007, 03:06 PM
Thanks slredstorm62,
All the wire harness is fine grounds are good. there are 4 motors would they each have a ground?
Old 04-10-2007, 08:35 PM
old_master's Avatar
Advisor/Moderator
Look at the harness under the carpet directly below the drivers feet area. Common problem.
Old 04-11-2007, 06:06 AM
Thanks folks I'll check it out!
