Old 04-10-2007, 09:21 AM
S10SNODOG's Avatar
S10SNODOG S10SNODOG is offline
Broken Seat Leaver
Some How The Seat Leaver Broke It Lookes As If Its Keyed How Do I Fix?
Old 04-10-2007, 07:37 PM
old_master's Avatar
Advisor/Moderator
Re: Broken Seat Leaver
This is a better alternative to replacing the recliner mechanism, which will break again...and again...and again. (Poor engineering design on GM's part.)
http://www.wittydeals.com/product_in...e6e9af94a18f70
Old 04-10-2007, 08:22 PM
old_master's Avatar
Advisor/Moderator
Is the crack visible? Visible hell, it shears the shaft right off! The recliner shaft breaks due to the stress involved in doing what it was designed to do. The force necessary to operate the recliner is greater than the recliner shaft can withstand after GM splines, slots, and then installs a screw down the center of a 7/16" diameter piece of cast aluminum! Once the weakend end of the shaft shears off, it exposes solid material, the replacement handle can be installed, and the problem goes away for good.
Old 04-11-2007, 10:36 AM
S10SNODOG's Avatar
Thank you very much for your answer and that site you have been around gm,s before
Old 05-13-2007, 09:19 AM
derrik38 derrik38 is offline
i just put a wood screw in mine and it works fine for now.
