Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 04-10-2007, 02:43 AM
robert_j_16 robert_j_16 is offline
Question 1987 toyota 4runner power windows
I have been trying to fix the power windows on my truck for a long time now. Neither of them are getting power. I checked all of the fuses in the cab and under the hood, I think it's some kind of circuit problem. I also checked the main fuse for the power windows. Now, I can run a wire from the batter and feed power directly to the windows, the driver side window works just fine, and the passenger side window gets power, but it isn't being grounded like it should. So my problem is this, I need to find out why their not getting power, and why the passenger side window also isn't getting grounded like it should. I think we have traced it to the power window relay, we found a diagram that (should) show where it's at, but it's not where they say it is. So if you have any info, any wiring diagrams or anything, please tell me where I can find the power window relay, or any other problems it might be. Thank you very much
Old 04-10-2007, 10:34 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: 1987 toyota 4runner power windows
Have you looked at the FSM ?
If not, check the 1st thread on the main page for a link to FSMs.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 04-10-2007, 12:52 PM
I'm sorry, I've heard allot of terms but I haven't heard FSM, I tried to find the thread with FSMs but I couldn't, If you explain it in a little more detail I'll be sure I check them tonight, Thank you for helping.
Old 04-10-2007, 03:47 PM
Actually, if FSM means (factory service manuel) I have looked at it, mine doesn't have anything really useful, no schematics or anything, just the basics. I did find a schematic in another book, but where it said the power window relay should be wasn't where it actually was, and I have yet to find it, and I still have to find out why their not getting power, thanks.
Old 04-12-2007, 10:18 AM
fourwd1's Avatar
AF -Advisor
H'mm, the schematics I have don't show a relay for the front windows, just the power locks.
89 4Runner - stock
Old 04-14-2007, 01:19 PM
Hey, I've looked at the schematics in a chiltons guide and they don't tell me as much as a motors manuel, their allot better. But I haven't been able to get my hands on a motors manuel. Or you were looking at a shematic for a lower class model with no power windows or something. Thanks for the help.
Old 09-09-2008, 06:51 PM
4runnerSr5 4runnerSr5 is offline
I have the same problem but havent been able to figure out the short I have checked the continuity but nothin.
Old 09-10-2008, 07:41 AM
fourwd1's Avatar
AF -Advisor
I found a schematic for an 85. It shows a relay (power main relay) for the power windows. There is also a fuse for the power windows located above the drivers kick panel fuse box (it's large and yellow IIRC, not a blade type fuse).
But if the windows are partially working it's not the relay or the fuse, but more likely a switch or wiring.
89 4Runner - stock
