Old 10-12-2002, 11:57 PM
Joe98Eclipse Joe98Eclipse is offline
Send a message via AIM to Joe98Eclipse
Talking Please Look At ME
I need the help of some people that have done neon under bodies on their eclipses. Where are the best locations for all 4 neons. Please help
Old 10-13-2002, 11:31 PM
98EclipseRSBLacK12 98EclipseRSBLacK12 is offline
Yeh i recently put one on my 98 eclipse rs....heres what to do....
for the sides: right under the door, there is a little lip that is straight....its about an inch wide...drill holes in that and use zipties.
for the back: look under ur car, go about a food into the car and ull see a metal bar.....drill holes in there and zip tie......
for the front: look right under teh front bumper....i didnt install the front but it cant be that hard...
mount the transformer to teh battery...ur good to go
Old 10-14-2002, 10:25 AM
wtng wtng is offline
Send a message via AIM to wtng
my goddamn front and side ones broke from bottoming out ..i had them in those exact locations..i really suggest moving them back more and up....really getting them up there..cuz they will shatter like nothing
Old 10-14-2002, 10:28 AM
I never heard of bottoming out on each of you car unless u go over a speedbump....
Well after I got my car, I put 17's on, and I think it raised the car an inch or two....if you have a lowered car, then I wouldnt suggest getting an undercar kit unless you wanna be very careful. Ive gone over curbs and shit with my eclipse and the tubes never brojke
Old 10-21-2002, 07:28 AM
turboracergsx's Avatar
turboracergsx turboracergsx is offline
Send a message via AIM to turboracergsx
first off how do you bottom out?.....dont run so low dummies!...second off i didnt use any stock stuf that came with my lights but the block,i used all my own wiring and stuff.i drilled holes in the metal lip in 3 places and used huge tie straps.before i mounte dmy light id put a layer of rubber cement between the light and chassis to help absorb shock.mout it up there with thick tie straps and then fill in gaps with rubber cement...............know what im sayin here? the stock stuff sux,plus if you break a tie strap the rubber cement will support your light till you replace the strap.it works,ive done it.peace.
1998 GSX-K&N intake,Custom cold air box,Greddy type-s,Tokico illumina suspention,1.75" drop,Khumo ecsta 712's,Purple neon under car kit,Dejon tools uicp,Dejon tools intake pipe,Magnacore 8.5 plug wires.
