Any1 knows how to reset a SRS light on? I forgot to hook up the airbag conector when i turned on the car, now te light wont go away.
Thanks. |
Re: SRS Light Reset????
dealership as far as i know.
-tony- 2000 honda s2000 |
thanks! i figured it out yesterday. dealer wants 80 for it. took me a pair of wires and 10 min to clear it out.
cool. saved yourself some money.
how do u reset it?? mine is on 2
there should be a yellow wire and connector on your fuseblock. it does not connect to anything except a dummy slot. pull this out ,theres should be 2 wires in there all you have to do is get a piec of speaker wires and short the connector, turn the ignition on but dont start. the srs light will go off in about 6 sec then disconnect the wire, then the light will come on again, quickly connect the wire and wait till it turns off then pull it off again. if done succesfully it will blink twice.
this will work if you have fixed the problem, if not it will stay on after you have reseted it. |
also some civic has green instead of yellow, depends on what year they are.
