Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 04-09-2007, 02:40 PM
roonie roonie is offline
92 sentra...help!
my daughter has a 92 sentra 1.6 standard trans.I changed the oil yesterday.I had the front of the car up on steel ramps.After doing the oil change the car idles fine but upon driving the car,it seems to be missing and running rough.I went for a drive and it seems like something is cutting out at a certain rpm.When the engine reaches this rpm,the engine begins to run intermittantly.Always at the same rpm.When i shift to a higher gear it seems to go away.The car lurches and chugs when i hit this certain rpm.When sitting idle and i rev. the engine..the engine revs and cuts out several times until i let off the gas pedal.Again...this happens when i reach a certain rpm only.I should also mention the fact that this problem seems to go a way and later come back when driving the car at different times...almost like a wiring short.Any help would be great.Just wondered if i got the float carb float stuck when i had it up on ramps...or does this car even have a carb (tbi)?thanks in advance
Old 04-10-2007, 10:04 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: 92 sentra...help!
No carb on your engine. Sounds like a possible short in the ECU, or something along the lines of spark(dist., plugs, wires). Probably just a coincidence that it happened after you changed the oil.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 05-20-2007, 03:44 AM
dreww dreww is offline
unless he somehow knocked a spart plug wire boot off a plug or the distributor. Not likely, but he may have dug around the engine while he was at it and accidentily did that.
Old 05-22-2007, 10:10 PM
06chill's Avatar
06chill 06chill is offline
yea or the tps sensors get sweet spots in them when they are drove at an rpm for a long time
06 Spec V CAI and more to come
Old 05-26-2007, 02:39 PM
slideways...'s Avatar
slideways... slideways... is offline
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
