Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 04-09-2007, 02:03 PM
ddg5006 ddg5006 is offline
Exclamation Looking for part can't find ? HELP PLEASE
I have a part number for a part that i am looking to have replaced in my car but i can't seem to find it. I tried a search in google but got no returned results, maybe someone here knows a way i don't. Any help would be appriceated.
Part Number : F87Z2C219KB
**update** well i called the dealer and the guy before gave me the wrong part munber it is supposed to be F87Z2C219CB
Old 04-09-2007, 02:05 PM
snupytcb snupytcb is offline
Re: Looking for part can't find ? HELP PLEASE
what is it and what's it for?
Old 04-09-2007, 02:07 PM
I have a 98 EXPLORER V6-245 4.0L SOHC
And the part should be the ABS module.
Old 04-09-2007, 02:09 PM
have you tried the dealer or a junkyard?
Old 04-09-2007, 02:12 PM
i got this part number straight from the dealer but i can't seem to find any record of it online. I'm trying to see if i can find the part cheaper. I did check the junkyards but to luck.
Old 04-09-2007, 02:16 PM
do they make an after market module?
Old 04-09-2007, 02:17 PM
not sure, just trying to find it as cheap as possible. or atlease do some reading on it
Old 04-09-2007, 11:11 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Fast Parts Networks shows it (http://www.trademotion.com/partlocat...fm?siteid=318). Still isn't cheap. If I were you, I'd certainly check out the system really well before replacing the ABS module. You can probably get the ABS codes read by a professional for around $90. That's quite a bit less than the $400.28 for a new OEM replacement.
Also, you can check out the rear axle speed sensor using an oscilloscope (preferred) or a Digital MultiMeter (DMM).
-Rod
Old 04-10-2007, 12:36 AM
reekor reekor is offline
I found one for you at a local (ontario) wreckers for $88.50US.
http://www.plazek.com/
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-10-2007, 12:54 PM
I looked on that site and found it but i can't be sure that this is the part it doesn't have any part number that i can match mine to. Thanks for your help though, i will inquire further about it to confirm the part number.
