Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 04-09-2007, 01:04 PM
n8zdogg n8zdogg is offline
1988 Corvette Brake dragging
right front caliper is dragging, have installed new flex line and caliper, still dragging. If I release the bleed screw, pressure releases and wheel turns fine. Any suggestions???
Old 01-14-2008, 06:38 PM
pappyfreebird pappyfreebird is offline
Re: 1988 Corvette Brake dragging
rookie on vets but have done a few brakes have you tried using a c clamp n pump the pistons back in (maybe just hangin up on crud)
Old 01-15-2008, 06:10 AM
16th hippy 16th hippy is offline
not the most familiar with the brake systems on the 88's, but for starters, if the caliper is new and the flex line is new(and not twisted up in any way), then i would say start looking at master cylinder. is possible the valve in it is sticking/or clogged and not allowing pressure to bleed back to master. if it has ABS/traction control(once again, not too sure about the '88 brake system), it could be a problem in the modulator valves. just tossing ideas out there to check. let us know what you come up with.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
