Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Astra/Astra Coupe/Kadett
Old 04-09-2007, 11:36 AM
jason_son jason_son is offline
astra not running correctly
my girlfriend has got a 1999 1.4 astra and it wont keep on running it starts up and tick over is unsteady and soon as u touch the peddle it cuts out theres no power can any one help me plz ?
Old 04-11-2007, 07:42 AM
autodesita autodesita is offline
Re: astra not running correctly
Hello I am partner in BYNKAAY company-we selling much interesting tools for kilometer tuning,dashboard calibration and car diagnostic for all different kinds of cars,please visit oure page: http://www.bynkaay.com/ and see if have interest for some tools,please contact with me and I will help you to order.When you make some order and if you use my ID(autodesita)you will have from me 2% discount form the pries and too free soft for the tool wich you select. My email adress is : [email protected]
Old 04-13-2007, 01:59 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Get a mechanic to plug in their diagnostic ECU(called OBDII) which will scan the computer for problems. Sounds like fuel pump, fuel filter or most likely, the camshaft position sensor(sensor is common for failure)
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
Old 12-06-2007, 05:03 AM
Boroboy Boroboy is offline
This forum may be useful:- http://www.vauxhallownersnetwork.co....splay.php?f=83
Old 02-20-2008, 06:11 PM
vx_tech vx_tech is offline
Theres no way of knowing for certain with out it being on a tech 2 or simualr scanner, I'm a vauxhall technican and see loads of astras weekly, the most common problem with the sypmtons you have discribed is a egr valve sticking open or shut more likey open weakening the mixture causing a stall. you didn't say if it was a 8v or a 16v.on the 8v engines there is a software download to disable the egr completely as they cause more trouble than they are worth,but as i said there is no way of knowing unless you have it scanned it would cost approx £60 from you local dealer probably cheaper elsewhere.
