| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
Help with Rear-End
I was wondering if anyone knew for sure....
Will a rear-end from a 96 Firebird fit under a 91 Camaro.... Both are coil spring setups. The Camaro measures APPROX...... Backingplates---56" Center of coil spring mounts-----40 1/2" If you know, let me know.... Thanks
EZ Online Mechanic Ryan '91 Chevrolet Camaro wit da Kenwood Hot 433 Stroker SBC (go-getta) |
Re: Help with Rear-End
Yeah the rear does fit under the 91. i belive your wheels will stick out about a inch or so on each side.
1993 Trans Am- Bone stock |
correct. it fits. i think your wheels will actually stick out somewhere between 1.5-2 inches.
90 Camaro RS V6 - swapped to V8 -350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft ESTIMATED 360-420 hp 380-430lb/ft torque
Thank you ...that is the answer I was hoping for!!
Do you know what the ratio is on that rear? I am running 3.73's right now, and really like them. Evidently, it is a stock rear, it does have the clutch packs, so I guess it is a posi-lock. That is my only reason for changing the rear, as I just put all new bearings in this one.
im pretty sure those cars came with varying gear sets. it's likely somewhere around 3.23/3.42. all you have to do is pull the cover off,count the ring gear teeth and the pinion gear teeth and the gear ratio = ring teeth % pinion teeth.
also you can put your 3.73s in that fourth gen rear too.
If it's out of a v8 car it MOST LIKELY has 3.42s
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
isnt it 3.42 for the manuals and then 3.23's for the autos?
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
some autos even had 2.73's. my brother in laws 98 z28 had those stock
I talked to the guy that I am getting it from......yes.....I am getting it!!! lol
Anyway, He said it is 3.42's, I don't think I will take too big of a hit going to these from a 3.73. I know the motor will handle it! How much do you think it is worth?? Thanks for all your help. I am coming here from a different forum, based here in St. Louis, and may I say, you guys are much more mature and helpful. Thanks again, and I look forward to talking to all of you more...... Sorry, those videos (in the multimedia section) aren't that great......more to come!
good. im glad you are having a good experience. welcome.
i would probably only pay aroun $220 for it... but that's not necessarily how much its worth.... that depends on what it means to you. I dont really know why you are swapping a 7.5" 10 bolt with 3.73s for another with 3.42s.... disc brakes???
yea... you're losing acceleration
I was thinking about swapping the gear set, keeping the 3.73's.......
Reason: Posi-lock
Lookign at your sig.... how long do you really think a 10 bolt will last behind that motor?
We are going to find out!!! P.S.----Not to metion the tranny......t-5!!!!!
You can't be serious with the T-5???
