Old 04-09-2007, 11:22 AM
Raimundo Raimundo is offline
Scanner
Any idea where I can find a Scanner for my 1987 Cherokee 4.0. I belive the MS 1700 is the one but i went to autozone, advance autopars, napa,central autoparts.... they don't have that one or symilar. thanks
Old 04-09-2007, 07:18 PM
citizen@large's Avatar
citizen@large citizen@large is offline
Re: Scanner
I've heard that snap-on sells a scanner, but it's like $3K USD!!! CRAZY $...
You're best off getting a factory service manual (FSM) and a volt/ohm meter. About $110 USD total.
Get the meter from advance or wherever, then buy the FSM for your year and it will tell you what connections on the two diagnostic ports under the hood to probe for which tests.
~Good Luck
Old 04-10-2007, 08:44 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Scanner
You probably won't need a scan tool for an 87..a 97 ..yes.
Old 04-10-2007, 10:55 AM
Re: Scanner
There is a connector to the left of the fuse box in my '87 is that the one to scan?
Old 04-10-2007, 07:29 PM
Re: Scanner
Should be under the hood if I remember right, by the fender.
