Old 04-09-2007, 09:09 AM
gunitsolja gunitsolja is offline
transmission problem!!
while driving home last night my tranny started making this weird grinding noise everytime i let go of the clutch and i had trouble putting it into gear??? i want to kno if this is a problem that can be fixed or just put a new tranny
Old 04-11-2007, 01:23 PM
CRXperiment's Avatar
CRXperiment CRXperiment is offline
Re: transmission problem!!
Check to make sure your shift linkage is properly attached and torque the bolts. Also check your tranny fluid level. I'm thinking it a bad gear selector fork in the tranny.
1989 Civic STD - sold
1991 CRX Si - current
Free Service Manuals: http://hondatech.info/
Old 04-11-2007, 02:25 PM
Scrapper Scrapper is offline
AF Premium User
sounds like your do for a clutch,presure pate,throw out bearing....
Old 04-11-2007, 07:19 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
No it doesn't.
As CRXperiment said, make sure you have enough fluid in it and aren't leaking from anywhere.
Honda Enthusiast
Old 04-11-2007, 11:01 PM
i tried putting fluid in it and it feels like it doesnt have any power anymore. it takes forever to pick up and when i down shift it pops out of second all the time so i gotta put it in nuetral and just brake... i have another tranny but it only has four gears...which brings me to my next question do u think i should just drop that one in or get another five speed??? if i put the four in would it make a huge difference in power???
Old 04-15-2007, 12:02 PM
welfarepc welfarepc is offline
just get another tranny they are cheap these days... check the local craigslist for someone parting out a car.
was your tranny fluid low when u topped it up?
Dan
Old 04-16-2007, 08:19 PM
yea it was low so im gonna try changing the clutch and see how it runs
Old 04-16-2007, 08:44 PM
If it was low and you burned out the tranny itself, don't bother changing the clutch if the tranny is gone. This will just be a waste of time since you probably need a new tranny anyway.
Old 04-16-2007, 10:46 PM
dont waste your money.
try putting honda MFT in it, or GM synchromesh fluid, that might help.
a new clutch wont help you put the transmission into gear
Dan
Old 04-17-2007, 06:35 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yup..in fact, I just burned mine out on a 70mi trip with no fluid...now I have no 2nd gear synchro
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
