Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-09-2007, 12:24 AM
2of9 2of9 is offline
2G turbo pistons?
well...i've looking around and couldnt find anything on the pros and cons about this mod. i do know that the 2g pistons have a higher CR than the 1G, just wondering if there any pros and cons because i maybe buying a laser turbo awd with a 2g pistons in it. thanks!
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 04-09-2007, 01:22 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 2G turbo pistons?
There's cons to it? If they are already in the car and nothing has to be done then I would say there are no cons whatsoever to it... The pros; it has higher compression and can withstand somewhere in the range of possibly up to 450hp... A good bit more than 1g pistons... And I would have to say thats about all there is to know about them in this case...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-09-2007, 01:48 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Only con I can think of is maybe whoever built the engine did a horseshit job on it *cough cough* like my car *cough cough*.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-09-2007, 10:48 AM
alrighty than! thanks guys.
--2OF9--
#808/1000
Old 04-10-2007, 01:27 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
The only cons would be having to get everything fitted together, but if it's already in the car then it's only pros for you buddy.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2007, 12:21 AM
j/w, but there would be power gains from this and if there is..would the ecu sense this? do i have to "tune" it? or would it be fine just cruisin around like any other dsm out there?
--2OF9--
#808/1000
Old 04-12-2007, 12:32 AM
I don't know if there would be any noticeable power gains out of it as far as the ECU monitoring goes, but no, you wouldn't need to "tune," just drive it as you normally would.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2007, 12:37 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
As far as power gains...you may notice a little differance when not under boost because I think the compression on the 2G pistions is 8.5:1 and I thought but dont quote me on this that the 1G pistons are like 8.0:1...
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 04-12-2007, 01:28 AM
Well yes, there will be power gains, but I was referring to the ECU, in terms that there won't need to be any tuning done.
95 Talon TSI AWD
97 Eclipse GST
Old 04-12-2007, 02:10 AM
Those numbers are correct.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-12-2007, 01:16 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Guess I heard wrong. I thought the stock 1G's were 7.8banghead:
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 04-12-2007, 01:33 PM
yeah, theres not much of a difference between 1g and 2g pistons compression. But it makes up a good bit of difference power-wise. Thats why I'm running 9.0:1
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-12-2007, 02:56 PM
Mikelb's Avatar
higher compression= more initial power with a smaller window for error
Old 04-13-2007, 01:35 AM
yeah..i'll probably drop in some 12.1:1 pistons in it! lmao..jk jk. thanks for replying guys!
--2OF9--
#808/1000
Old 04-13-2007, 04:57 AM
I like living on the edge. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
