Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 04-08-2007, 10:49 PM
at1212b at1212b is offline
97 Corolla not straight after front-end work
My gf's corolla just had front work done due to a loud noise so it was sent to a shop to get it fixed last week. I noticed when I was driving it after it was serviced at the shop, for the car to go straight, the steering wheel has to be pointed at 1oclock. It was aligned correctly before. I assume the mechanic didn't align something correctly after he replaced the parts and should fix it without charge?
Thank you
Old 06-12-2007, 09:11 AM
rockwood84 rockwood84 is offline
Re: 97 Corolla not straight after front-end work
did you take it back to the shop
Old 06-12-2007, 11:55 AM
AFROsamuri AFROsamuri is offline
Yeah you would be correct in saying he didnt align everything right...it really wont hurt anything for the steering wheel to sit like that but if you want it fixed then you should take it back to the shop...and if they dont do it then you can usually get underneath the car if you look at where the steering rod comes out of the firewall...follow the rod down untill you find where you find the bolt connected to the rack and pinion...loosen it turn the steering wheel back to twelve oclock, and tightin the bolt agian.
AFROsamuri
-1996 Geo Prizm (DAILY GRIND) *R.I.P*
-1995 Lincoln Towncar (NEW DAILY GRIND)
-2000 Ford Focus (AUDIO/VISUAL)
-1983 Toyota Corolla SR5 (PROJECT CAR)
