Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-08-2007, 08:46 PM
hahapopcorn hahapopcorn is offline
car goin crazy
i was drivin earlier today and tried boosting the car..and when it got to around 4k on the rpm it was bogging like CRAZY, super fast jerks etc. when i got home and checked under the hood the valve cover was cracked and there was oil leaking, is that the reason? If so, is all i have to do is replace the cover and im good to go? or is there something that Caused the crack and is there something else that i should be checking for? thanks. Also the spark plugs have been changed recently but its been a while on the wires.
update: I tried putting JB weld in the crack and it didnt seem to leak for about a day or so, now its back to the way it was -_-;; im a cheap bastard Lol
Old 04-08-2007, 09:16 PM
Killa's Avatar
Killa Killa is offline
Re: car goin crazy
I dont care to know about you. BUT I DO CARE TO KNOW YOUR CAR INFO.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 04-08-2007, 09:17 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: car goin crazy
You might want to get the valve cover replaced. JB weld isn't going to hold forever, although it does a damn good job. And yes, something like that will cause problems. Engines are built to only allow air in/out at certain areas. If air starts coming in/out at a place it's not supposed to, then it's going to cause problems. That's why leaks of any kinds (including valve cover cracks) are bad.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-11-2007, 04:06 PM
Re: car goin crazy
it is a 1995 eagle talon tsi awd w/ a 92 head
Old 04-11-2007, 05:55 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: car goin crazy
Did you get a CEL? And what kind of plugs did you put in? Regular NGK's are the best and that's what you should have used. If you put in some platinums, then they probably fouled out right away and that's what's causing the jerking when you get on the gas when the boost starts to build.
95 Talon TSI AWD
97 Eclipse GST
Old 04-16-2007, 02:05 AM
Re: car goin crazy
update::: i fixed the valve cover and it was fine for about a day, now it is starting to do it again. is it possible that the spark plug wires have gone bad? or are misplaced? (i don't have the manual anymore so if anyone could possibly tell me the correct order in which they go in that would be great thanks) the spark plugs i have replaced recenty about 1k miles ago they are the NGK copper ones. is it also possible that it is because of my intake filter? i was going to clean it but never remembered to (its suppose to be red but now its black as hell) i'm scared as hell that this is possibly a symptom of my turbo going bad -.-...thanks to everyone who has helped me so far and appreciate further advice
Old 04-17-2007, 02:02 AM
Re: car goin crazy
i am getting closer to the problem. when i checked the spark plugs there was ALOT of carbon build up around the tip, i asked a couple shops about it but they charge a ridiculous amount to get it checked -.- i'm hella low on money. they said it could be that the turbos wastegate might not be working properly or something like that. has anyone else had a similar problem?
Old 04-17-2007, 09:27 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: car goin crazy
it could possibly be the wastegate not functioning right... I suggest checking your vacuum lines
I also suggest checking for a boost leak...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
