Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 04-08-2007, 08:21 PM
p71 JD's Avatar
p71 JD p71 JD is offline
AC going bad?
My 99 Tc has this little problem. When I turn on the AC it does not turn on. I leave it on and after a while it will start up and work perfectly. Then when I turn off the car and start it up again it works correctly for a few days, then the same cycle starts again. It seems like if a relay is taking time to click on,anyone have an idea whats going on??
99 lincoln Town Car Executive
Old 04-08-2007, 08:25 PM
snupytcb snupytcb is offline
Re: AC going bad?
you should turn the a/c on highest setting and check for power at compresser. if no power check both sides of all sensors inline.
Old 04-08-2007, 10:07 PM
reekor reekor is offline
Re: AC going bad?
Bad relay
Low refrigerant
Bad pressure switch.
Poor connection at A/C clutch or pressure switch.
[quote=p71 JD]My 99 Tc has this little problem. When I turn on the AC it does not turn on. I leave it on and after a while it will start up and work perfectly. Then when I turn off the car and start it up again it works correctly for a few days, then the same cycle starts again. It seems like if a relay is taking time to click on,anyone have an idea whats going on??[/QUOT
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 04-14-2007, 04:38 PM
p71 JD's Avatar
Re: AC going bad?
I took it in for service. The blower was bad,$145.00 total for the fix.
