Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-08-2007, 02:39 PM
ABigWeaney ABigWeaney is offline
idle surge...
OK i have a 92 tsi.. i have idle surge that i cant get rid of... i replaced the coil, turbo, bov, isc, ecu capacitors, intake manifold gasket, 02 sensor, 0 rings in the tb... and some more stuff.... and it is still surging but when i take the innercooler piping off of the tb and restrict the air flow it corrects its self... the throttle cable is not tight, i ran out of stuff that i can replace. it all happened when it jumped timing.. could it be a bent intake valve?
I also cleaned the manifold and the tb really good.
Old 04-08-2007, 04:19 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: idle surge...
It could be the bent valve. When it jumped did you hear a hit from the engine? You may also want to check the EGR valve also. Could be dirty/broken.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-08-2007, 04:58 PM
Re: idle surge...
i don't remember hearing any noises.. but the vacuum gage is at about 15.. i think the needle should be moving if it had a bent valve... I removed the egr a few months before all of this started happening. It is so confusing
Old 04-10-2007, 12:39 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: idle surge...
Have you done a compression test? That should tell you if you bent a valve badly enough to affect any performance.
95 Talon TSI AWD
97 Eclipse GST
Old 04-10-2007, 07:36 AM
Re: idle surge...
yes i done a compression test, it was 160 for 4-2 and 130 for 1.
Old 04-10-2007, 09:18 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: idle surge...
Then that is your problem. 130 is too low
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-10-2007, 12:24 PM
Re: idle surge...
what could be causing that? bent valve or bad rings? head gasket? or could it be any of them..
Old 04-10-2007, 06:47 PM
Re: idle surge...
It could be any of them. A leakdown test will tell you more if you can get ahold of one of those bad boys.
95 Talon TSI AWD
97 Eclipse GST
Old 04-11-2007, 07:38 AM
Re: idle surge...
crap.... oh well ill just rebuild it and make it better
