Old 04-08-2007, 01:50 PM
guitarfish's Avatar
guitarfish guitarfish is offline
Front end problem?
Guys,
My 2002 GP GT has 162K on it and is in great shape overall, however I think the front end has something wrong.
Over the winter, I began to notice a slight vibration in the front end at 60+ mph. Spring came and I got two new tires mounted and balanced, however, there was little noticable improvement in the front end.
I drove my son's '04 GP the other night, at 70mph it's smooth as silk. However, mine is an uncomfortable ride, a slight but ever present unevenness that will make things like a CD case sitting on the seat, or the headrests, slightly move back and forth.
This afternoon while replacing the front brakes, I did the 3-9 o'clock and 6-12 o'clock check on each wheel. 6-12 o'clock is perfect, no play or movement, no noise. However, 3-9 o'clock makes a definite klunk-klunk sound on each wheel.
What does this sound like? Tie rods ends? I replaced my wheel bearings around 100K, I think they're OK. I need to get this puppy smooth again.
Thanks
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
1994 GP SE - 231,000
1997 GP GT - 134,000
1998 GP GT - 225,000
2002 GP GT - 222,000
Old 04-09-2007, 08:20 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Front end problem?
With 162K miles I'd considering replacing at least both outer tie rod ends. Replacing the inner is a different story and difficult. When was the last alignment? An alignment shop should be able to tell you what steering and/or suspension components are worn out. With bad tie rods the toe in/out will be out of spec.
Timeslip 08/12/06
AF Community Guidelines
Old 04-09-2007, 08:25 AM
guitarfish's Avatar
This morning I decided to drop it off at a shop I use. They've done alignments for me before, and it's been about a year (35K miles). I have a feeling it will be the outer tie rod ends.
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
