Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 04-08-2007, 11:43 AM
70Nova05 70Nova05 is offline
Question Throttle linkage differences between 1969 and 1970
Hey all:
Does anyone happen to know if and what the differences are between 1969 and 1970 throttle linkage? I have a 1970 SS but a 1969 Rochester Q-Jet was all I could find at the time. 1970 uses a throttle cable, and I picked up the correct throttle bracket for a 70, however I can only get about 3/4 throttle out of this setup. Should I be using a completely different setup?
The cable is not super tight, and only has about a 1/16 inch of slack in it. It just won't pull the full distance to open the secondary's all the way. The pedal seems fine, hardware in good shape, and it goes all the way to the floor. There is no slop at the top of the pedal.
Any ideas would be very welcome.
Old 04-13-2007, 08:08 AM
Blue Bowtie's Avatar
Registered Offender
Re: Throttle linkage differences between 1969 and 1970
You can either lengthen the arm on the pedal or shorten the center distance at the carb belcrank.
