Go Back   Automotive Forums Car Chat > Toyota > ES300/ES330/Windom
Old 04-08-2007, 09:26 AM
QualityVehicle QualityVehicle is offline
1996 es300 overheating puzzle?
I had to swap motors in my 1996 es300 (rod bearing), so I had my mechanic put in a good (?) junkyard motor that had 120,000 miles on it. It runs purrrrfect now sitting still. I idled it for two hours with no problem, but if I drive it down the road, it overheats. I am at a loss. Can anyone help me out? Thanks.
Old 04-08-2007, 09:32 AM
snupytcb snupytcb is offline
Re: 1996 es300 overheating puzzle?
hate to say it but it may be a head issue.
Old 04-08-2007, 10:04 AM
Scrapper Scrapper is offline
AF Premium User
could be head gasket or cracked head.but look in your radiator see if it's circulating if not could water pump....
Old 04-08-2007, 07:19 PM
KimMG KimMG is offline
AF - Advisor
Clogged radiator?
Old 04-09-2007, 05:48 AM
The car didn't overheat with the other engine, so I'm thinking it cant be the rediator. I guess that leaves the heads or the water pump. Since the cap isn't on top of the radiator, it's kinda hard to see how well the water is moving. I guess a compression test would eliminate (or point to) the heads, which should only leave water pump???
Old 04-10-2007, 12:46 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Welcome to the AF!
Could be your thermostat. If it won't open very far, it would produce the symptoms you describe.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-10-2007, 04:07 PM
AutoMaintenanceGuy AutoMaintenanceGuy is offline
the actual junkyard motor is probably the problem. drain the oil out and see if the oil looks a milky brown. that would tell you it is a head gasket problem.
